Home » Language IDEs » C / C++ IDE (CDT) » Post-build steps Command objdump direct to file
Post-build steps Command objdump direct to file [message #1844066] Tue, 31 August 2021 02:34 Go to next message
I use internel builder in eclipse, then I put "objdump.exe a.elf > a.dump" in post-build steps command, the contents of disassemble just appear in CDT build console,but not redirect to file. later i use "objdump.exe a.elf 2&>1 | tee a.dump",but it still not work as I expected.
It is a lack of CDT?
How can I redirect objdump to file in internal builder after build finished?
Help!!!
[Updated on: Wed, 01 September 2021 05:36] by Moderator
Re: Post-build steps Command objdump direct to file [message #1844103 is a reply to message #1844066] Wed, 01 September 2021 08:31 Go to previous message
The internal builder may not be using the shell and you are using a shell feature.
Try specifying the command to be executed with a shell.
In Linux, that would be something like: bash -c "objdump.exe a.elf > a.dump"
Windows cmd.exe has similar capability but I don't remember the option (maybe /c ?)
[Updated on: Wed, 01 September 2021 08:33] by Moderator
Previous Topic:Configuring Eclipse for cross compiling AD 2012 version ?
Next Topic:Indexing problem after debugging
Current Time: Sat Jul 19 11:16:06 EDT 2025
Powered by FUDForum. Page generated in 0.03513 seconds
