Home » Modeling » M2T (model-to-text transformation) » Share a (E)MTL file using a JAR dependency
Share a (E)MTL file using a JAR dependency [message #1844080] Tue, 31 August 2021 10:19 Go to next message
I'm trying to put all my common stuff into a JAR. I have several Maven projects, let's say:
- acceleo-commons
- acceleo-project-1
In the first one I put:
- a customized MTL to EMTL compiler (using AcceleoCompilerHelper)
- a customized generator (using AbstractAcceleoGenerator)
In the second there is the model and the MTL files. This is working well.
Now I'd like to also share some utilities like a logger. I have the files "logger.mtl" and "Logger.java" in "acceleo-project-1" that I'd like to put into "acceleo-commons". I spent a lot of time with the debugger to understand how the dependencies are resolved but I didn't find any way to do that. Is this possible?
David
Re: Share a (E)MTL file using a JAR dependency [message #1844083 is a reply to message #1844080] Tue, 31 August 2021 12:00 Go to previous message
The EMTL builder does not always work well. If you search the forum you will find at least a couple of messages where I explain my workarounds.
Ed Willink
Previous Topic:From Ecore to Java
Next Topic:Generate text on Annotation
Current Time: Sat Jul 19 23:49:09 EDT 2025
Powered by FUDForum. Page generated in 0.03480 seconds
