Home » Eclipse Projects » Oomph » Can Oomph import code templates?
Can Oomph import code templates? [message #1843264] Wed, 21 July 2021 15:08 Go to next message
Can I import code templates with an Oomph SetupTask?
As those code templates are all stored into a single preference, i want to avoid to overwrite existing templates.
Hence I ask for import.
More precisely I mean those in the Preferences > Java > Editor > Templates
Frank
Re: Can Oomph import code templates? [message #1843266 is a reply to message #1843264] Thu, 22 July 2021 02:28 Go to previous messageGo to next message
There is specialized merging support for this:
https://git.eclipse.org/c/oomph/org.eclipse.oomph.git/tree/plugins/org.eclipse.oomph.setup/src/org/eclipse/oomph/setup/impl/PreferenceTaskImpl.java#n973
So it should merge /add each <template> based on its id="..." value.
Re: Can Oomph import code templates? [message #1843274 is a reply to message #1843266] Thu, 22 July 2021 07:05 Go to previous messageGo to next message
I tried it.
The templates that come with Eclipse were still available. But another template that i created before, did get removed.
Is there a bug, or do I need to do something differnet?
  <setupTask
      xsi:type="setup:CompoundTask"
      name="Preferences">
    <annotation
        source="http://www.eclipse.org/oomph/setup/UserPreferences"/>
    <setupTask
        xsi:type="setup:PreferenceTask"
        key="/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.custom_templates"
        value="&lt;?xml version=&quot;1.0&quot; encoding=&quot;UTF-8&quot; standalone=&quot;no&quot;?>&lt;templates>&lt;...;/template>&lt;/templates>">
      <description>Some description</description>
    </setupTask>
  </setupTask>
Re: Can Oomph import code templates? [message #1843279 is a reply to message #1843274] Thu, 22 July 2021 09:35 Go to previous messageGo to next message
It's very easy to create a development environment.
https://www.eclipse.org/setups/installer/?url=http://git.eclipse.org/c/oomph/org.eclipse.oomph.git/plain/setups/configurations/OomphConfiguration.setup&show=true
There will be a launcher to launch an IDE and you can set a breakpoint in org.eclipse.oomph.setup.impl.PreferenceTaskImpl.XMLPreferenceHandler.XMLPreferenceHandler(URI, String, String[], String[]) and in org.eclipse.oomph.setup.impl.PreferenceTaskImpl.ListPreferenceHandler.merge() to see if something is going wrong. In the debug launched IDE, use Navigate -> Open Setup -> Workspace and copy your task to the workspace setup. When you Perform Setup Tasks... in this IDE, you will be able to debug. If there is a bug, you can help fix it.
Re: Can Oomph import code templates? [message #1843280 is a reply to message #1843274] Thu, 22 July 2021 09:35 Go to previous messageGo to next message
Re: Can Oomph import code templates? [message #1843339 is a reply to message #1843280] Sat, 24 July 2021 01:02 Go to previous messageGo to next message
https://git.eclipse.org/c/oomph/org.eclipse.oomph.git/tree/plugins/org.eclipse.oomph.setup/src/org/eclipse/oomph/setup/impl/PreferenceTaskImpl.java#n977
Line 977
I think the problem is the configured attribute name, is should not be "id", but instead "name".
     registry.put(URI.createURI("//instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.custom_templates"), new Factory() //$NON-NLS-1$
        public PreferenceHandler create(URI key)
          //return new XMLPreferenceHandler(key, "template", new String[] { "id" }, null); //$NON-NLS-1$ //$NON-NLS-2$
          return new XMLPreferenceHandler(key, "template", new String[] { "name" }, null); //$NON-NLS-1$ //$NON-NLS-2$
An entry looks like this:
<template autoinsert="true" context="java" deleted="false" description="D..." enabled="true" name="doc">...</template>
Re: Can Oomph import code templates? [message #1843340 is a reply to message #1843280] Sat, 24 July 2021 01:02 Go to previous messageGo to next message
Line 977
Re: Can Oomph import code templates? [message #1843342 is a reply to message #1843340] Sat, 24 July 2021 02:07 Go to previous messageGo to next message
Hmm. The existing templates use a style like this:
<template autoinsert="true" context="gettercomment_context" deleted="false" description="Comment for getter method" enabled="true" id="org.eclipse.jdt.ui.text.codetemplates.gettercomment" name="gettercomment">/**
 * @return the ${bare_field_name}
 */</template>
And the name is something you can edit but the ID is not something you can edit. But you're right of course that if you add your own template, it doesn't have an ID. E.g., here's where I add one and edit an existing one:
<?xml version="1.0" encoding="UTF-8" standalone="no"?><templates>
<template autoinsert="true" context="javadoc" deleted="false" description="author name" enabled="true" id="org.eclipse.jdt.ui.templates.author" name="@author">@author - ${user}</template>
<template autoinsert="true" context="java" deleted="false" description="foo" enabled="true" name="bar">foo bar</template>
</templates>
So it would seem better to use the name given there isn't necessarily an id=...
Please open a Bugzilla.
Re: Can Oomph import code templates? [message #1843343 is a reply to message #1843342] Sat, 24 July 2021 02:29 Go to previous message
done:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=575012
Previous Topic:Eclipse Installation Error
Next Topic:P2 error using archived Babel - handshake_failure
Current Time: Sun Jul 20 16:48:32 EDT 2025
Powered by FUDForum. Page generated in 0.04163 seconds
