Home » Newcomers » Newcomers » Error when create a BOM entry from a XOM(Error Message:  java.lang.NullpointException when create a BOM entry from XOM from Rule project of Rule Designer plugin in eclipse Oxygen (version 4.7.3a))
Error when create a BOM entry from a XOM [message #1842205] Fri, 11 June 2021 12:08 Go to next message
Please help!
steps to create error
(1) Installed Rule Designer plugin for eclipse Oxygen(4.7.3a).
(2) Create one main rule project
(3) Import XOM from Java Execution Object Model (java project). It created a java project classes zip file  In resources\xom-library folder.
(4) Create BOM entry from XOM
(5) Choose XOM entry by selecting java project
(6) Select one specific class and push finish button and see error message  java.lang.NullpointException
I checked xom-libray zip file and I can find the specific class file existing.
It looks configuration issue of Rule Project ?
Lun Yi
Re: Error when create a BOM entry from a XOM [message #1842206 is a reply to message #1842205] Fri, 11 June 2021 12:27 Go to previous messageGo to next message
This page
https://marketplace.eclipse.org/content/ibm-operational-decision-manager-developers-rule-designer
says "For additional information and support, go to the IBM Operational Decision Manager Developer Center (https://developer.ibm.com/odm/)" so that's probably the best approach. I doubt anyone here knows anything specific about this stuff...
Re: Error when create a BOM entry from a XOM [message #1842209 is a reply to message #1842206] Fri, 11 June 2021 13:42 Go to previous messageGo to next message
Error stack as bellow, it should be Rule Designer plugin issue.
ENTRY ilog.rules.studio.bom.wizards 4 4 2021-06-11 11:40:31.817
!MESSAGE java.lang.NullPointerException
!STACK 0
at ilog.rules.bom.util.IlrClassUtilities$GenericSignatureWriter.writeBounds(IlrClassUtilities.java:228)
at ilog.rules.bom.util.IlrClassUtilities$GenericSignatureWriter.writeTypeVariable(IlrClassUtilities.java:212)
at ilog.rules.bom.util.IlrClassUtilities$GenericSignatureWriter.writeType(IlrClassUtilities.java:184)
at ilog.rules.bom.util.IlrClassUtilities$GenericSignatureWriter.write(IlrClassUtilities.java:176)
at ilog.rules.bom.dynamic.IlrDynamicClass.getName(IlrDynamicClass.java:593)
at ilog.rules.bom.util.IlrModelUtilities.getFullyQualifiedName(IlrModelUtilities.java:148)
at ilog.rules.bom.dynamic.IlrDynamicModelElement.computeFullyQualifiedName(IlrDynamicModelElement.java:200)
at ilog.rules.bom.dynamic.IlrDynamicModelElement.getFullyQualifiedName(IlrDynamicModelElement.java:192)
at ilog.rules.factory.proxy.IlrPackageProxy.getClasses(IlrPackageProxy.java:147)
at ilog.rules.factory.proxy.IlrPackageProxy.accept(IlrPackageProxy.java:469)
at ilog.rules.util.IlrVisitor.callAccept(IlrVisitor.java:94)
at ilog.rules.bom.util.IlrCoherentSelector$ClassLookup$ClassDefLookup.callAccept(IlrCoherentSelector.java:270)
at ilog.rules.util.IlrVisitor.visit(IlrVisitor.java:82)
at ilog.rules.util.IlrVisitor.iterateVisit(IlrVisitor.java:46)
at ilog.rules.factory.proxy.IlrPackageProxy.accept(IlrPackageProxy.java:470)
at ilog.rules.bom.dynamic.IlrDynamicObjectModel.accept(IlrDynamicObjectModel.java:1225)
at ilog.rules.bom.util.IlrCoherentSelector$ClassLookup.<init>(IlrCoherentSelector.java:203)
at ilog.rules.bom.util.IlrCoherentSelector.<init>(IlrCoherentSelector.java:61)
at ilog.rules.bom.util.IlrMergeWizard.init(IlrMergeWizard.java:1538)
at ilog.rules.bom.util.IlrMergeWizard.<init>(IlrMergeWizard.java:73)
at ilog.rules.studio.bom.wizards.newfile.IlrNewBOMWizardXomPage$5.run(IlrNewBOMWizardXomPage.java:478)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:119)
Re: Error when create a BOM entry from a XOM [message #1842210 is a reply to message #1842209] Fri, 11 June 2021 14:15 Go to previous message
Indeed it should be. And because the entire stack trace is stuff that is not org.eclipse.* and was not developed at Eclipse.org it's highly unlikely that anyone here can help you with that issue. Rather you must ask the people who provided that plugin/library...
Previous Topic:running trouble
Next Topic:Where is jakarta ee 9 web project eclipse-jee-2020-12
Current Time: Sun Jul 20 15:41:13 EDT 2025
Powered by FUDForum. Page generated in 0.08477 seconds
