Home » Eclipse Projects » Eclipse Scout » NullPointerException(Using table default filter mechanism an error occur )
NullPointerException [message #1841763] |
Thu, 27 May 2021 22:55  |
Good day,
I am facing this problem when using the default table filter mechanism.
2021-05-28 02:38:33,312 INFO [scout-model-thread-11] org.eclipse.scout.rt.ui.html.json.MainJsonObjectFactory - Using following object factories: [org.eclipse.scout.rt.ui.html.JsonObjectFactory@619b98a0, adn.gov.ph.govservices.ui.html.ZeroClickJsonObjectFactory@407b0ac] -Ex: MDC[principal=user, httpUri=, uiSession=, clientSession=1qv7hod4dqeeer1d09mn7i03e5i58k0djejsqcmmqhi1alfvpdvd, jobName=Starting JsonClientSession, cid=pB4az8vF2qv/1]
2021-05-28 02:38:33,407 INFO [qtp315138752-45] org.eclipse.scout.rt.ui.html.UiSession - UiSession with ID 1:9gmusktgtstfjnohu2avvruuhom26cv99rasg9o9k63mlfl38ko initialized -Ex: MDC[principal=user, httpUri=, uiSession=, clientSession=, jobName=, cid=pB4az8vF2qv/1]
2021-05-28 02:38:33,408 INFO [qtp315138752-45] org.eclipse.scout.rt.ui.html.json.JsonMessageRequestHandler - Created new UI session with ID 1:9gmusktgtstfjnohu2avvruuhom26cv99rasg9o9k63mlfl38ko in 2309.089994 ms [maxIdleTime=14400s, httpSession.maxInactiveInterval=3600s] -Ex: MDC[principal=user, httpUri=, uiSession=, clientSession=, jobName=, cid=pB4az8vF2qv/1]
2021-05-28 02:38:41,557 ERROR [scout-model-thread-22] org.eclipse.scout.rt.platform.exception.ExceptionHandler - NullPointerException:n/a -Ex: java.lang.NullPointerException: null
at org.eclipse.scout.rt.client.ui.basic.table.AbstractTable$P_TableUIFacade.fireFilterAddedFromUI(AbstractTable.java:4934)
at org.eclipse.scout.rt.client.ModelContextProxy.lambda$1(ModelContextProxy.java:49)
at org.eclipse.scout.rt.platform.chain.callable.CallableChain$Chain.continueChain(CallableChain.java:227)
at org.eclipse.scout.rt.platform.transaction.TransactionProcessor.runTxMandatory(TransactionProcessor.java:156)
at org.eclipse.scout.rt.platform.transaction.TransactionProcessor.runTxRequired(TransactionProcessor.java:139)
at org.eclipse.scout.rt.platform.transaction.TransactionProcessor.intercept(TransactionProcessor.java:78)
at org.eclipse.scout.rt.platform.chain.callable.CallableChain$Chain.continueChain(CallableChain.java:222)
at org.eclipse.scout.rt.platform.chain.callable.CallableChain.call(CallableChain.java:170)
at org.eclipse.scout.rt.platform.context.RunContext.call(RunContext.java:158)
at org.eclipse.scout.rt.client.ModelContextProxy.lambda$0(ModelContextProxy.java:49)
at com.sun.proxy.$Proxy33.fireFilterAddedFromUI(Unknown Source)
at org.eclipse.scout.rt.ui.html.json.table.JsonTable.handleUiFilterAdded(JsonTable.java:952)
at org.eclipse.scout.rt.ui.html.json.table.JsonTable.handleUiEvent(JsonTable.java:629)
at org.eclipse.scout.rt.ui.html.json.JsonEventProcessor.processEvent(JsonEventProcessor.java:52)
at org.eclipse.scout.rt.ui.html.json.JsonEventProcessor.processEvents(JsonEventProcessor.java:37)
at org.eclipse.scout.rt.ui.html.UiSession.processJsonRequestInternal(UiSession.java:817)
at org.eclipse.scout.rt.platform.util.concurrent.Callables.lambda$0(Callables.java:31)
at org.eclipse.scout.rt.platform.job.internal.ExceptionProcessor.intercept(ExceptionProcessor.java:41)
at javax.security.auth.Subject.doAs(Subject.java:422)
at org.eclipse.scout.rt.platform.security.SubjectProcessor.intercept(SubjectProcessor.java:43)
at org.eclipse.scout.rt.platform.context.RunContextRunner.intercept(RunContextRunner.java:38)
at org.eclipse.scout.rt.platform.job.internal.CallableChainExceptionHandler.intercept(CallableChainExceptionHandler.java:33)
at org.eclipse.scout.rt.platform.job.internal.JobFutureTask.lambda$0(JobFutureTask.java:106)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at org.eclipse.scout.rt.platform.job.internal.JobFutureTask.run(JobFutureTask.java:175)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
at org.eclipse.scout.rt.platform.job.internal.NamedThreadFactory$1.run(NamedThreadFactory.java:63)
MDC[principal=user, httpUri=, uiSession=1:9gmusktgtstfjnohu2avvruuhom26cv99rasg9o9k63mlfl38ko, clientSession=1qv7hod4dqeeer1d09mn7i03e5i58k0djejsqcmmqhi1alfvpdvd, jobName=Processing JSON request, cid=Xu6KU3FV9Yw/5]
2021-05-28 02:38:41,614 ERROR [scout-model-thread-21] org.eclipse.scout.rt.platform.exception.ExceptionHandler - NullPointerException:n/a -Ex: java.lang.NullPointerException: null
but on tablepage the default filter mechanism works just fine..
For additional information, i used these properties/settings:
pom.xml
<properties>
<adn.gov.ph.govservices.version>${project.version}</adn.gov.ph.govservices.version>
<jdk.source.version>1.8</jdk.source.version>
<org.eclipse.scout.rt.version>10.0.18</org.eclipse.scout.rt.version>
<maven.compiler.target>1.8</maven.compiler.target>
<maven.compiler.source>1.8</maven.compiler.source>
<project.build.sourceEncoding>UTF-8</project.build.sourceEncoding>
</properties>
Eclipse IDE version: 2021-03 (4.19.0)
Could someone give me a hand please.
Re: NullPointerException [message #1841766 is a reply to message #1841763] |
Fri, 28 May 2021 01:58   |
I solve the problem.
Before, i use initTableInternal() method to initially load the data into the table itself, like:
before:
protected void initTableInternal() {
// TODO Auto-generated method stub
deleteAllRows();
Object[][] result = BEANS.get(IXXService.class).getXXTableData(..);
addRowsByMatrix(result);
Every time i will use the table default filter mechanism it always throws a NullPointerException error, i do not know yet as to how or why, hope someone could give me a hint. But after removing the though the table is empty but the filter mechanism just works fine. So, to initially load the table data i have tried to use method of the form, like:
after:
protected void initFieldInternal() {
deleteAllRows();
and hollah, it works.. The data is loaded into the table and the filter mechanism works.. SOLVED!
But the question remains, why is it using throw an error exception, is it related to my code within the method? I like to know the exact reason. If you have any idea please share it to me.. Thank you..
Re: NullPointerException [message #1841817 is a reply to message #1841769] |
Mon, 31 May 2021 03:12  |
Hello André,
Thank you so much, you provided me more than enough information. So the cause of the error is me being lack of reading and information, haha what a naive i am. So it is really those codes specifically the method i injected/used that cause the error and the missed-use of "internal" method.
I have to review my application now cause i think i did the same approach on some of my forms.
Up to the last word of your reply André is very much helpful to me and you always showed me the right way.
Thank you very much once again.
Sincerely,
Mark
Current Time: Sun Jul 20 17:10:36 EDT 2025
Powered by FUDForum. Page generated in 0.03930 seconds
