Home » Eclipse Projects » Sirius » Using an operation to change the style of elements in my model using an action call/operation
Using an operation to change the style of elements in my model using an action call/operation [message #1841566] Thu, 20 May 2021 15:51 Go to next message
I have an operation that is defined in my metamodel that is accessed via java action call from a popup menu in my model. What I want to do is to be able to change the border of the elements that are returned from my operation. Not sure if it would be better to be done in the java action or the operation, or for that matter how to actually change the style of the elements using java. Any help or suggestions?
[Updated on: Fri, 21 May 2021 09:24] by Moderator
Re: Using an operation to change the style of elements in my model using an action call/operation [message #1841660 is a reply to message #1841566] Tue, 25 May 2021 03:40 Go to previous messageGo to next message
You can use the java action. Here is an example of code to change the border of a container:
org.eclipse.sirius.diagram.DDiagramElementContainer myContainer = AAA;
org.eclipse.sirius.diagram.ContainerStyle containerStyle = myContainer.getOwnedStyle();
org.eclipse.sirius.diagram.LineStyle newBorderLineStyle = LineStyle.BBB;
int newBorderSize = CCC;
containerStyle.setBorderSize(newBorderSize);
containerStyle.setBorderLineStyle(newBorderLineStyle);
// You hava to add the changed features to the "custom features" list to avoid that your changes are "deleted" at the next refresh.
containerStyle.getCustomFeatures().add(DiagramPackage.eINSTANCE.getBorderedStyle_BorderSize().getName());
containerStyle.getCustomFeatures().add(DiagramPackage.eINSTANCE.getBorderedStyle_BorderLineStyle().getName());
Re: Using an operation to change the style of elements in my model using an action call/operation [message #1841686 is a reply to message #1841660] Tue, 25 May 2021 13:10 Go to previous messageGo to next message
For an element that isn't a container what is the command instead of getOwnedStyle()?
Also where can I find the whole example, it looks like there is no declaration of BBB or LineStyle so the line:
Spits out an error of undeclared variables.
One more thing to note is that I run into this error whenever I try to declare a variable as type DDiagramElement*:
Caused by: java.lang.ClassCastException: class wFP_V2.impl.Data_ElementImpl cannot be cast to class org.eclipse.sirius.diagram.DDiagramElement (wFP_V2.impl.Data_ElementImpl is in unnamed module of loader org.eclipse.osgi.internal.loader.EquinoxClassLoader @70161b7c; org.eclipse.sirius.diagram.DDiagramElement is in unnamed module of loader org.eclipse.osgi.internal.loader.EquinoxClassLoader @1478f7ec)
I have everything imported correctly I think so I'm not sure how to resolve this class error.
The full error message that I receive is:
!ENTRY org.eclipse.gmf.runtime.diagram.ui 4 4 2021-05-25 14:03:46.150
!MESSAGE execute
!STACK 0
org.eclipse.core.commands.ExecutionException: While executing the operation, an exception occurred
	at org.eclipse.core.commands.operations.DefaultOperationHistory.execute(DefaultOperationHistory.java:504)
	at org.eclipse.sirius.diagram.ui.tools.internal.editor.DDiagramCommandStack.execute(DDiagramCommandStack.java:73)
	at org.eclipse.sirius.diagram.ui.tools.internal.editor.DDiagramCommandStack.execute(DDiagramCommandStack.java:54)
	at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack.execute(DiagramCommandStack.java:157)
	at org.eclipse.sirius.diagram.ui.tools.internal.menu.PopupMenuContribution$1.run(PopupMenuContribution.java:423)
	at org.eclipse.jface.action.Action.runWithEvent(Action.java:474)
	at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:580)
	at org.eclipse.jface.action.ActionContributionItem.lambda$4(ActionContributionItem.java:414)
	at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:89)
	at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4209)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1037)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4026)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3626)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1157)
	at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:338)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1046)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:155)
	at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:644)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:551)
	at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:156)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:152)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
	at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:64)
	at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
	at java.base/java.lang.reflect.Method.invoke(Method.java:564)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1461)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1434)
	at WFP.design.myAction.execute(myAction.java:64)
	at org.eclipse.sirius.tools.api.command.view.JavaActionFromToolCommand.doExecute(JavaActionFromToolCommand.java:95)
	at org.eclipse.emf.transaction.RecordingCommand.execute(RecordingCommand.java:135)
	at org.eclipse.emf.common.command.CompoundCommand.execute(CompoundCommand.java:261)
	at org.eclipse.sirius.diagram.ui.tools.api.command.GMFCommandWrapper.doExecuteWithResult(GMFCommandWrapper.java:104)
	at org.eclipse.gmf.runtime.emf.commands.core.command.AbstractTransactionalCommand.doExecute(AbstractTransactionalCommand.java:248)
	at org.eclipse.emf.workspace.AbstractEMFOperation.execute(AbstractEMFOperation.java:150)
	at org.eclipse.sirius.diagram.ui.tools.internal.commands.WrappingCommandIgnoringAffectedFiles.execute(WrappingCommandIgnoringAffectedFiles.java:125)
	at org.eclipse.core.commands.operations.DefaultOperationHistory.execute(DefaultOperationHistory.java:496)
[Updated on: Tue, 25 May 2021 14:08] by Moderator
Re: Using an operation to change the style of elements in my model using an action call/operation [message #1841694 is a reply to message #1841660] Tue, 25 May 2021 16:03 Go to previous messageGo to next message
Also if it helps here is my code where I am trying to type cast from one of my defined types to the DDiagramElement type:
public EList forwardImpactAnalysis() {
		// TODO: implement this method
		// Ensure that you remove @generated or mark it @generated NOT
		EList<? extends Input> inputs = getInput();
		Iterator<? extends Input> itInput = inputs.iterator();
		while (itInput.hasNext()) {
			Input nextInput = itInput.next();
			EList<? extends Output> outputs = nextInput.getTgt().getOutput();
			Iterator<? extends Output> itOutput = outputs.iterator();
			EList<Data_Element> dataOutputs = new BasicEList();
			while (itOutput.hasNext()) {
				Output nextOutput = itOutput.next();
				dataOutputs.add((Data_Element) nextOutput.getTgt());
				DDiagramElement myElement = (DDiagramElement) nextOutput;
				System.out.println(myElement);
			return (EList)dataOutputs;
		//throw new UnsupportedOperationException();
		EList empty = new BasicEList();
		return empty;
The print statements are just there to help with debugging and understanding how a lot of these commands work and what their outputs are.
[Updated on: Tue, 25 May 2021 16:04] by Moderator
Re: Using an operation to change the style of elements in my model using an action call/operation [message #1841702 is a reply to message #1841694] Wed, 26 May 2021 03:05 Go to previous messageGo to next message
As the javadoc says "ClassCastException is thrown to indicate that the code has attempted to cast an object to a subclass of which it is not an instance.". Here you try to cast a wFP_V2.impl.Data_ElementImpl (a class of your metamodel I suppose) into a org.eclipse.sirius.diagram.DDiagramElement. It can't work, there is no magic. To retrieve a DDiagramElement from a semantic element, you can see how to do it in the Cookbook.
I extract this piece of code from the test org.eclipse.sirius.tests.unit.diagram.compartment.CompartmentsLayoutTest.
And indeed, AAA, BBB, CCC do not exist. You have to replace them by the values you want...
Re: Using an operation to change the style of elements in my model using an action call/operation [message #1841722 is a reply to message #1841702] Wed, 26 May 2021 10:24 Go to previous messageGo to next message
OH well that was dumb of me, should have realized that!
Also thanks for the cookbook, I'll see if I can cook something up that can work for me!
Re: Using an operation to change the style of elements in my model using an action call/operation [message #1841753 is a reply to message #1841702] Thu, 27 May 2021 10:52 Go to previous messageGo to next message
I do have a follow-up question with regards to the line from the cookbook:
Collection<EObject> result = new EObjectQuery(mySemanticElement).getInverseReferences(ViewpointPackage.Literals.DSEMANTIC_DECORATOR__TARGET);
This line does return a collection of the DDiagramElements that I want, however it seems to return the same element multiple times. I switched it to a Set instead of a Collection and it still returns the same element multiple times and I'm not sure why or how. My diagram only has one element that it should be returning so I don't understand why this is happening.
Re: Using an operation to change the style of elements in my model using an action call/operation [message #1841785 is a reply to message #1841753] Fri, 28 May 2021 11:38 Go to previous messageGo to next message
The inverse references returned is for all the session; so for all diagrams. Maybe your semantic element is represented in several diagrams. But even with that, the DDiagramElement should not be the same.
I don't really understand.
Re: Using an operation to change the style of elements in my model using an action call/operation [message #1841904 is a reply to message #1841785] Wed, 02 June 2021 12:59 Go to previous message
I figured out a workaround for the issue of there being multiples of the same element within a set. Still not sure why it was happening but it's working well enough now.
I do have another follow-up question now however. For my editor I can create multiple viewpoints of the same semantic model. All of these viewpoints are unsynchronized so that the user can then drag and drop the specific elements that they want to use, edit, and manipulate without having to navigate the whole model. My issue now is when I try to change the border color of the nodes. Since the viewpoints are all unsynchronized I assumed that the border changes would happen locally within the viewpoint where the method is being called. But for whatever reason when the method is called it changes the color randomly throughout all the viewpoints and sometimes won't change the color at all. And then when I try a containerStyle.getBordercolor() returns that the RGB values have been changed despite not showing up in my model. Any idea about how to resolve this to get the changes to happen locally to the viewpoint and not randomly throughout the model?
This is the code that I came up with to change the color recursively throughout my model based on the element that I want:
public void forwardImpactAnalysis() {
		EList<? extends Input> inputs = this.getInput();
				Data dataOutput = (Data) itOutput.next().getTgt();
				//This line will return the same element that is put in, but instead of as an ecore class it will be of a sirius class that will allow for the manipulation of the concrete syntax in the model instance.
				Set<? extends DSemanticDecorator> result = (Set<? extends DSemanticDecorator>) new EObjectQuery(
						dataOutput).getInverseReferences(ViewpointPackage.Literals.DSEMANTIC_DECORATOR__TARGET);
				DDiagramElementContainer myContainer = (DDiagramElementContainer) result.iterator().next();
				RGBValues newBorderColor = RGBValues.create(255, 0, 0);
				containerStyle.setBorderColor(newBorderColor);
				containerStyle.getCustomFeatures().add(DiagramPackage.Literals.BORDERED_STYLE__BORDER_COLOR.getName());
				dataOutput.forwardImpactAnalysis();
Previous Topic:How to set table cell values programmatically?
Next Topic:[ANN] Sirius 6.5.0
Current Time: Sun Jul 20 13:28:25 EDT 2025
Powered by FUDForum. Page generated in 0.04574 seconds
