Home » Eclipse Projects » Kura » Kura and Java 11
Kura and Java 11 [message #1838069] Mon, 15 February 2021 05:45 Go to next message
Hi, I would like to know if there are any current future plans to move Eclipse Kura to Java 11?
Best regards Martin
Re: Kura and Java 11 [message #1838070 is a reply to message #1838069] Mon, 15 February 2021 05:49 Go to previous messageGo to next message
it is not in the plans for Kura 5.0.0 to have an official and full runtime support for Java 11.
For this version, we have made the build process compatible with Java 11 but only build-wise.
Looking at the issues and forum comments, as of now, there should not be big impediments to run Kura on Java 11.
Matteo
Re: Kura and Java 11 [message #1839317 is a reply to message #1838070] Fri, 19 March 2021 05:04 Go to previous messageGo to next message
Hi Metteo, thanks for your reply. I am currently trying to import the Kura Git repository (developer) into Eclipse as described in the Git. For this I took the Eclipse EE 2019.06 and selected OOmph in the import section and imported Kura there. But I can't start the emulator because some bundles are not found and some bundles have errors.
My workspace looks like this:
see attachement
The error message when I start the emulator looks like this:
!SESSION 2021-03-19 09:53:23.196 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_282
java.vendor=Private Build
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=de_DE
!ENTRY org.eclipse.osgi 2 0 2021-03-19 09:53:23.478
!MESSAGE The property 'osgi.configuration.area' with the value 'file:/home/biskup/Programming/EclipseKuraDevelop/EclipseHome/eclipse-workspace/.metadata/.plugins/org.eclipse.pde.core/Eclipse Kura Emulator/' is being overriden by the OSGi standard configuration property 'org.osgi.framework.storage' with the value '/tmp/osgi/framework_storage'.
!STACK 0
java.lang.IllegalArgumentException: The property 'osgi.configuration.area' with the value 'file:/home/biskup/Programming/EclipseKuraDevelop/EclipseHome/eclipse-workspace/.metadata/.plugins/org.eclipse.pde.core/Eclipse Kura Emulator/' is being overriden by the OSGi standard configuration property 'org.osgi.framework.storage' with the value '/tmp/osgi/framework_storage'.
	at org.eclipse.osgi.internal.location.EquinoxLocations.<init>(EquinoxLocations.java:87)
	at org.eclipse.osgi.internal.framework.EquinoxConfiguration.<init>(EquinoxConfiguration.java:548)
	at org.eclipse.osgi.internal.framework.EquinoxContainer.<init>(EquinoxContainer.java:104)
	at org.eclipse.osgi.launch.Equinox.<init>(Equinox.java:53)
	at org.eclipse.osgi.launch.Equinox.<init>(Equinox.java:46)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.startup(EclipseStarter.java:315)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:251)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:657)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:594)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1438)
!ENTRY org.eclipse.kura.json.marshaller.unmarshaller.provider 4 0 2021-03-19 09:53:24.239
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.kura.json.marshaller.unmarshaller.provider [29]
  Unresolved requirement: Import-Package: org.eclipse.kura.core.inventory.resources; version="[1.0.0,2.0.0)"
  Unresolved requirement: Import-Package: org.eclipse.kura.core.configuration; version="[2.0.0,3.0.0)"
    -> Export-Package: org.eclipse.kura.core.configuration; bundle-symbolic-name="org.eclipse.kura.core.configuration"; bundle-version="2.0.300.qualifier"; version="2.0.0"
       org.eclipse.kura.core.configuration [14]
         Unresolved requirement: Import-Package: org.eclipse.kura.core.util; version="[1.0.0,2.0.0)"
           -> Export-Package: org.eclipse.kura.core.util; bundle-symbolic-name="org.eclipse.kura.core"; bundle-version="1.0.600.qualifier"; version="1.2.0"
              org.eclipse.kura.core [19]
                Unresolved requirement: Import-Package: org.h2; version="1.4.199"
	at org.eclipse.osgi.container.Module.start(Module.java:463)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel$2.run(ModuleContainer.java:1845)
	at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor$1$1.execute(EquinoxContainerAdaptor.java:136)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1838)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1781)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1743)
	at org.eclipse.osgi.container.SystemModule.startWorker(SystemModule.java:269)
	at org.eclipse.osgi.container.Module.doStart(Module.java:605)
	at org.eclipse.osgi.container.Module.start(Module.java:468)
	at org.eclipse.osgi.container.SystemModule.start(SystemModule.java:193)
	at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:439)
	at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:458)
	at org.eclipse.osgi.launch.Equinox.start(Equinox.java:139)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.startup(EclipseStarter.java:338)
!ENTRY org.eclipse.kura.xml.marshaller.unmarshaller.provider 4 0 2021-03-19 09:53:24.242
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.kura.xml.marshaller.unmarshaller.provider [42]
  Unresolved requirement: Import-Package: org.eclipse.kura.core.configuration.metatype; version="[1.0.0,2.0.0)"
    -> Export-Package: org.eclipse.kura.core.configuration.metatype; bundle-symbolic-name="org.eclipse.kura.core.configuration"; bundle-version="2.0.300.qualifier"; version="1.0.0"
!ENTRY org.eclipse.kura.asset.provider 4 0 2021-03-19 09:53:24.775
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.kura.asset.provider [4]
  Unresolved requirement: Import-Package: org.eclipse.kura.core.configuration.util; version="[2.0.0,3.0.0)"
    -> Export-Package: org.eclipse.kura.core.configuration.util; bundle-symbolic-name="org.eclipse.kura.core.configuration"; bundle-version="2.0.300.qualifier"; version="2.0.0"
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1665)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234)
	at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:345)
!ENTRY org.eclipse.kura.camel.cloud.factory 4 0 2021-03-19 09:53:24.783
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.kura.camel.cloud.factory [8]
!ENTRY org.eclipse.kura.core.cloud 4 0 2021-03-19 09:53:24.791
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.kura.core.cloud [12]
  Unresolved requirement: Import-Package: org.eclipse.kura.core.data
    -> Export-Package: org.eclipse.kura.core.data; bundle-symbolic-name="org.eclipse.kura.core"; bundle-version="1.0.600.qualifier"; version="1.1.0"
!ENTRY org.eclipse.kura.core.configuration 4 0 2021-03-19 09:53:24.794
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.kura.core.configuration [14]
!ENTRY org.eclipse.kura.core.deployment 4 0 2021-03-19 09:53:24.796
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.kura.core.deployment [16]
!ENTRY org.eclipse.kura.core.net 4 0 2021-03-19 09:53:24.798
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.kura.core.net [17]
!ENTRY org.eclipse.kura.core 4 0 2021-03-19 09:53:24.800
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.kura.core [19]
!ENTRY org.eclipse.kura.emulator.net 4 0 2021-03-19 09:53:24.848
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.kura.emulator.net [24]
  Unresolved requirement: Import-Package: org.eclipse.kura.core.net; version="[1.0.0,1.1.0)"
    -> Export-Package: org.eclipse.kura.core.net; bundle-symbolic-name="org.eclipse.kura.core.net"; bundle-version="1.0.600.qualifier"; version="1.0.5"
!ENTRY org.eclipse.kura.web2 4 0 2021-03-19 09:53:24.858
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.kura.web2 [33]
  Unresolved requirement: Import-Package: org.apache.felix.useradmin; version="1.0.0"
!ENTRY org.eclipse.kura.wire.component.provider 4 0 2021-03-19 09:53:24.867
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.kura.wire.component.provider [37]
  Unresolved requirement: Import-Package: org.eclipse.kura.asset.provider; version="[2.0.0,2.1.0)"
    -> Export-Package: org.eclipse.kura.asset.provider; bundle-symbolic-name="org.eclipse.kura.asset.provider"; bundle-version="2.0.300.qualifier"; version="2.0.0"
!ENTRY org.eclipse.kura.wire.provider 4 0 2021-03-19 09:53:24.874
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.kura.wire.provider [40]
Framework is running in emulation mode
2021-03-19T09:53:25,013 [Start Level: Equinox Container: e7ef00d4-a9d6-47eb-9535-394c288894b1] INFO  o.a.c.i.o.Activator - Camel activator starting
2021-03-19T09:53:25,038 [Start Level: Equinox Container: e7ef00d4-a9d6-47eb-9535-394c288894b1] INFO  o.a.c.i.o.Activator - Camel activator started
[Updated on: Fri, 19 March 2021 05:08] by Moderator
Re: Kura and Java 11 [message #1839669 is a reply to message #1839317] Thu, 25 March 2021 08:32 Go to previous messageGo to next message
it may be that currently develop is broken in terms of the default configuration of the emulator.
For now I may suggest to manually select the missing dependency and retry to start the environment
Re: Kura and Java 11 [message #1840641 is a reply to message #1838069] Wed, 21 April 2021 04:57 Go to previous message
The same error, all are already selected.
Previous Topic:Connect to broker on pi
Next Topic:Change log level at runtime
Current Time: Sun Jul 20 17:09:48 EDT 2025
Powered by FUDForum. Page generated in 0.03234 seconds
