Home » Eclipse Projects » GEF » GEF5 FX: Using Connection(How do I add Label and Color to a Connection?)
GEF5 FX: Using Connection [message #1840411] Wed, 14 April 2021 14:12 Go to next message
Im just began using the framework GEF by following the Guide on Itemis with the title "Getting started with GEF" (cant post links new account).
In this guide a mindmap is created step by step. The Tutorial uses org.eclipse.gef.fx.nodes.Connection as the Connection visual between Nodes.
My Problem is, that i want to modify the Color of these Connections and add a Label to the Connection, that is set to the middle of the Connection. But looking at the Class, I cant find a way to do that. The Connection class does have functions setStartDecoration() and setEndDecoration(), but thats all i was able to find for modifying the appearance of a Connection.
Im still very limited in my skills and maybe im missing something. Help would be appreciated.
Re: GEF5 FX: Using Connection [message #1840431 is a reply to message #1840411] Thu, 15 April 2021 03:16 Go to previous messageGo to next message
The Connection contains a JavaFX Node for its rendering; this is the node you need to customize. For example:
Node curve = connection.getCurve();
if (curve instanceof GeometryNode) {
	((GeometryNode<?>) curve).setStroke(lineColor);
Labels can be added as children of the Connection Part, and/or anchored to the connection
HTH,
Camille
Re: GEF5 FX: Using Connection [message #1840465 is a reply to message #1840431] Thu, 15 April 2021 15:35 Go to previous messageGo to next message
Hey,
thanks for your reply! Im now able to set the color of connections.
Im still struggling with adding Text to a Connection though. I tried using AnchorKey and DynamicAnchor, but it seems like too many not fully understood things are involved and no attempt has worked out yet.
If I understand this correctly:
I dont think the text needs its own ContentPart and be added as child to the ConnectionPart.
So anchoring it dynamically to the center of the connection should be enough.
A slightly detailed explanation on how to do such thing would be very helpful.
Re: GEF5 FX: Using Connection [message #1840479 is a reply to message #1840411] Fri, 16 April 2021 02:55 Go to previous message
Usually, you do not want to comprise the label within the connection figure, as you want it be controlled by its own VisualPart (so you can drag it independent on the connection). GEF MVC uses the concept of "anchoring" VisualParts to others to realize this, we also provide a specific "link-feedback"-concept to highlight the relationship. Even if you do not want to drag it individually, you can use the anchoring concept to have an own VisualPart for it, which is helpful for anchoring selection feedback in this case.
I recommend you take a look at the FX examples ( https://github.com/eclipse/gef/wiki/FX-Examples#examples-undeployed) and the Zest examples (https://github.com/eclipse/gef/wiki/Zest-Examples#examples-undeployed).
[Updated on: Fri, 16 April 2021 02:57] by Moderator
Previous Topic:Please ADD information about "GEF DOT End-User Tools" settings
Next Topic:Exception in gef shapes example:java.lang.NoClassDefFoundError: Could not initialize class org.eclip
Current Time: Sun Jul 20 15:17:20 EDT 2025
Powered by FUDForum. Page generated in 0.04010 seconds
