Unable to clone repo in ssh or https in 5.12 [message #1840404] |
Wed, 14 April 2021 10:22  |
Hi Folks,
ENV:
OSX v 11.1 (20C69)
Eclipse: Version: 2020-12 (4.18.0), Build id: 20201210-1552
E/JGIT: Git integration for Eclipse 5.12.0.202104110038 org.eclipse.egit.feature.group Eclipse EGit
I think I'm seeing an issue similar to this:
https://www.eclipse.org/forums/index.php/m/1836909
When I tried to push changes to a branch in a repo which had been working fine up until my latest eclipse update (maybe the previous one tbh - I've been doing docs and so I think I autoupdated in eclipse twice in the past week) I was getting errors. git operations from the commandline worked fine. So I decided to try and start fresh and removed the local branch and repo from eclipse, restart and try again.
When I try and clone the repo via ssh, I now get this error:
eclipse.buildId=4.18.0.I20201202-1800
java.version=15.0.2
java.vendor=AdoptOpenJDK
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_US
Framework arguments: -product org.eclipse.epp.package.jee.product -product org.eclipse.epp.package.jee.product -keyring /Users/billbabcock/.eclipse_keyring
Command-line arguments: -os macosx -ws cocoa -arch x86_64 -product org.eclipse.epp.package.jee.product -data file:/Users/billbabcock/Documents/ -product org.eclipse.epp.package.jee.product -keyring /Users/billbabcock/.eclipse_keyring
org.eclipse.egit.ui
Error
Wed Apr 14 10:07:17 EDT 2021
git@github.REDACTED:REDACTED/REDACTED.git: DefaultAuthFuture[ssh-connection]: Failed (UnsupportedOperationException) to execute: remove
org.eclipse.jgit.api.errors.TransportException: git@github.REDACTED:REDACTED/REDACTED.git: DefaultAuthFuture[ssh-connection]: Failed (UnsupportedOperationException) to execute: remove
at org.eclipse.jgit.api.LsRemoteCommand.execute(LsRemoteCommand.java:189)
at org.eclipse.jgit.api.LsRemoteCommand.call(LsRemoteCommand.java:128)
at org.eclipse.egit.core.op.ListRemoteOperation.run(ListRemoteOperation.java:116)
at org.eclipse.egit.ui.internal.clone.SourceBranchPage$9.run(SourceBranchPage.java:375)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:122)
Caused by: org.eclipse.jgit.errors.TransportException: git@github.REDACTED:REDACTED/REDACTED.git: DefaultAuthFuture[ssh-connection]: Failed (UnsupportedOperationException) to execute: remove
at org.eclipse.jgit.transport.sshd.SshdSessionFactory.getSession(SshdSessionFactory.java:250)
at org.eclipse.jgit.transport.sshd.SshdSessionFactory.getSession(SshdSessionFactory.java:1)
at org.eclipse.jgit.transport.SshTransport.getSession(SshTransport.java:107)
at org.eclipse.jgit.transport.TransportGitSsh$SshFetchConnection.<init>(TransportGitSsh.java:281)
at org.eclipse.jgit.transport.TransportGitSsh.openFetch(TransportGitSsh.java:153)
at org.eclipse.jgit.api.LsRemoteCommand.execute(LsRemoteCommand.java:167)
... 4 more
Caused by: org.apache.sshd.common.SshException: DefaultAuthFuture[ssh-connection]: Failed (UnsupportedOperationException) to execute: remove
at org.apache.sshd.common.future.AbstractSshFuture.lambda$verifyResult$1(AbstractSshFuture.java:131)
at org.apache.sshd.common.future.AbstractSshFuture.formatExceptionMessage(AbstractSshFuture.java:185)
at org.apache.sshd.common.future.AbstractSshFuture.verifyResult(AbstractSshFuture.java:130)
at org.apache.sshd.client.future.DefaultAuthFuture.verify(DefaultAuthFuture.java:39)
at org.apache.sshd.client.future.DefaultAuthFuture.verify(DefaultAuthFuture.java:32)
at org.apache.sshd.common.future.VerifiableFuture.verify(VerifiableFuture.java:68)
at org.eclipse.jgit.transport.sshd.SshdSession.connect(SshdSession.java:164)
at org.eclipse.jgit.transport.sshd.SshdSession.connect(SshdSession.java:99)
at org.eclipse.jgit.transport.sshd.SshdSessionFactory.getSession(SshdSessionFactory.java:237)
... 9 more
Caused by: java.lang.UnsupportedOperationException: remove
at java.base/java.util.Iterator.remove(Iterator.java:102)
at org.eclipse.jgit.internal.transport.sshd.JGitKexExtensionHandler.handleServerSignatureAlgorithms(JGitKexExtensionHandler.java:147)
at org.eclipse.jgit.internal.transport.sshd.JGitKexExtensionHandler.handleKexExtensionRequest(JGitKexExtensionHandler.java:108)
at org.apache.sshd.common.kex.extension.KexExtensionHandler.handleKexExtensionsMessage(KexExtensionHandler.java:160)
at org.apache.sshd.common.session.helpers.AbstractSession.handleKexExtension(AbstractSession.java:625)
at org.apache.sshd.common.session.helpers.AbstractSession.doHandleMessage(AbstractSession.java:483)
at org.apache.sshd.common.session.helpers.AbstractSession.handleMessage(AbstractSession.java:428)
at org.apache.sshd.common.session.helpers.AbstractSession.decode(AbstractSession.java:1463)
at org.apache.sshd.common.session.helpers.AbstractSession.messageReceived(AbstractSession.java:388)
at org.eclipse.jgit.internal.transport.sshd.JGitClientSession.messageReceived(JGitClientSession.java:199)
at org.apache.sshd.common.session.helpers.AbstractSessionIoHandler.messageReceived(AbstractSessionIoHandler.java:64)
at org.apache.sshd.common.io.nio2.Nio2Session.handleReadCycleCompletion(Nio2Session.java:358)
at org.apache.sshd.common.io.nio2.Nio2Session$1.onCompleted(Nio2Session.java:335)
at org.apache.sshd.common.io.nio2.Nio2Session$1.onCompleted(Nio2Session.java:332)
at org.apache.sshd.common.io.nio2.Nio2CompletionHandler.lambda$completed$0(Nio2CompletionHandler.java:38)
at java.base/java.security.AccessController.doPrivileged(AccessController.java:312)
at org.apache.sshd.common.io.nio2.Nio2CompletionHandler.completed(Nio2CompletionHandler.java:37)
at java.base/sun.nio.ch.Invoker.invokeUnchecked(Invoker.java:127)
at java.base/sun.nio.ch.Invoker.invokeDirect(Invoker.java:158)
at java.base/sun.nio.ch.UnixAsynchronousSocketChannelImpl.implRead(UnixAsynchronousSocketChannelImpl.java:568)
at java.base/sun.nio.ch.AsynchronousSocketChannelImpl.read(AsynchronousSocketChannelImpl.java:276)
at java.base/sun.nio.ch.AsynchronousSocketChannelImpl.read(AsynchronousSocketChannelImpl.java:297)
at org.apache.sshd.common.io.nio2.Nio2Session.doReadCycle(Nio2Session.java:429)
at org.apache.sshd.common.io.nio2.Nio2Session.handleReadCycleCompletion(Nio2Session.java:362)
at java.base/sun.nio.ch.Invoker$2.run(Invoker.java:219)
at java.base/sun.nio.ch.AsynchronousChannelGroupImpl$1.run(AsynchronousChannelGroupImpl.java:112)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1130)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:630)
at java.base/java.lang.Thread.run(Thread.java:832)
And when I try via HTTPS, I get this:
java.version=15.0.2
Framework arguments: -product org.eclipse.epp.package.jee.product -keyring /Users/billbabcock/.eclipse_keyring
Command-line arguments: -os macosx -ws cocoa -arch x86_64 -product org.eclipse.epp.package.jee.product -keyring /Users/billbabcock/.eclipse_keyring
org.eclipse.egit.ui
Error
Wed Apr 14 00:53:57 EDT 2021
When trying to open a connection to https://github.REDACTED/REDACTED/REDACTED.git/info/lfs/objects/batch the server responded with an error code. rc=401
org.eclipse.jgit.api.errors.JGitInternalException: When trying to open a connection to https://github.REDACTED/REDACTED/REDACTED.git/info/lfs/objects/batch the server responded with an error code. rc=401
at org.eclipse.jgit.api.CloneCommand.call(CloneCommand.java:207)
at org.eclipse.egit.core.op.CloneOperation.run(CloneOperation.java:194)
at org.eclipse.egit.ui.internal.clone.AbstractGitCloneWizard.executeCloneOperation(AbstractGitCloneWizard.java:488)
at org.eclipse.egit.ui.internal.clone.AbstractGitCloneWizard.access$2(AbstractGitCloneWizard.java:481)
at org.eclipse.egit.ui.internal.clone.AbstractGitCloneWizard$6.run(AbstractGitCloneWizard.java:460)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
Caused by: java.io.IOException: When trying to open a connection to https://github.REDACTED/REDACTED/REDACTED.git/info/lfs/objects/batch the server responded with an error code. rc=401
at org.eclipse.jgit.lfs.SmudgeFilter.downloadLfsResource(SmudgeFilter.java:150)
at org.eclipse.jgit.lfs.SmudgeFilter.<init>(SmudgeFilter.java:105)
at org.eclipse.jgit.lfs.SmudgeFilter.<init>(SmudgeFilter.java:91)
at org.eclipse.jgit.attributes.FilterCommandRegistry.createFilterCommand(FilterCommandRegistry.java:115)
at org.eclipse.jgit.dircache.DirCacheCheckout.runBuiltinFilterCommand(DirCacheCheckout.java:1631)
at org.eclipse.jgit.dircache.DirCacheCheckout.getContent(DirCacheCheckout.java:1574)
at org.eclipse.jgit.dircache.DirCacheCheckout.checkoutEntry(DirCacheCheckout.java:1487)
at org.eclipse.jgit.dircache.DirCacheCheckout.doCheckout(DirCacheCheckout.java:563)
at org.eclipse.jgit.dircache.DirCacheCheckout.checkout(DirCacheCheckout.java:467)
at org.eclipse.jgit.api.CloneCommand.checkout(CloneCommand.java:377)
at org.eclipse.jgit.api.CloneCommand.call(CloneCommand.java:204)
... 5 more
All the auth tokens are fine and verified.
If I clone from the commandline I am able to switch branches, and pull fine it seems.
All thoughts and suggestions are welcome.
- bill
Re: Unable to clone repo in ssh or https in 5.12 [message #1840413 is a reply to message #1840409] |
Wed, 14 April 2021 14:17   |
Yes, I can see from the stack traces that the HTTPS clone got further. It failed after having received the upstream git repo data, but then hit a snag when checking out. The SSH problem is much earlier; it fails during the initial connection to the upstream.
The SSH problem should be fixed now. Try updating EGit/Jgit from the EGit nightly update site. (Don't forget to reload it in Eclipse first.)
I would appreciate feedback whether the fix really works. This problem didn't occur in my tests against github.com or other servers, and since I don't know what your github instance replies in the SSH protocol, I have no way to test the fix.
As for the LFS problem when cloning over HTTPS: I don't use LFS myself, so I may be a bit confused. But according to the LFS documentation, it seems there is auto-detection of the LFS URL only for SSH. It's not quite clear to me how one would clone a repository containing LFS-managed files over HTTPS. If you clone this repo with command-line git over https, does that put the real large files from the LFS server into your working tree? If it doesn't put the real LFS data into the working tree, what does it put there? Are there any lfs-related properties set in the git config, such as lfs.url or remote.origin.lfsurl?
FUDForum. Page generated in 0.04308 seconds
