Home » Modeling » Epsilon » Using reflection
Using reflection [message #1820543] Wed, 22 January 2020 08:48 Go to next message
Hi all. I was wondering if there is a way to call a user defined operation in EOL with a sort of reflection style ...for instance by name.
This means that if I have an operation in my eol file called :
getPersons() on a specific context, i would like to call it by operation name. this is because I have this info in my models. Is it possible ?
Re: Using reflection [message #1820550 is a reply to message #1820543] Wed, 22 January 2020 10:45 Go to previous messageGo to next message
Hi Ludovico,
To my knowledge this is not possible, however I'm not sure why you would need this. There are two workarounds I can think of. The first is to generate your EOL program using EGL/EGX for a given model. Basically you paste your EOL code into an EGL template and use dynamic sections to retrieve and output the operation call. Another is to define helper methods which call the desired operation based on the model. For example, if the operation you want to call is defined in your model, you could have an operation with a "switch" statement on the model element property which defines this method and call it like that.
operation Any callOperation(operationName : String) {
    switch (operationName) {
        case "foo": return self.foo();
        case "bar": return self.bar();
        case "baz": return self.baz();
        default: throw "Unknown operation '"+operationName+"'";
Re: Using reflection [message #1820551 is a reply to message #1820550] Wed, 22 January 2020 10:50 Go to previous messageGo to next message
Thanks Sina, actually the first solution is how I have already implemented, but I thought I could further automate the process. Thanks for confirming it.
Re: Using reflection [message #1820562 is a reply to message #1820551] Wed, 22 January 2020 16:32 Go to previous messageGo to next message
Hi Ludovico,
Below is a terrible solution for calling operations reflectively.
var s = "";
s.call("foo").println();
s.call("bar").println();
operation String foo() : String {
	return "foo";
operation String bar() : String {
	return "bar";
operation Any call(op : String) : Any {
	var m = new Native("org.eclipse.epsilon.eol.EolModule");
	m.parse("return target." + op + "();");
	m.operations.addAll(System.context.module.operations);
	m.context.frameStack.put("target", self);
	return m.execute();
Dimitris
Re: Using reflection [message #1820563 is a reply to message #1820562] Wed, 22 January 2020 16:41 Go to previous messageGo to next message
... and below is a more decent solution.
var s = "";
	return "foo";
	return "bar";
	return System.context.module.
		operations.selectOne(o|o.name = op).
		execute(self, /*parameters*/ Sequence{}, System.context);
Dimitris
Re: Using reflection [message #1820587 is a reply to message #1820563] Thu, 23 January 2020 09:03 Go to previous messageGo to next message
I suppose we could also add this logic to the end of OperationCallExpression.execute. For example the following seems to work:
if (module instanceof IEolModule &&
    "call".equals(operationName) &&
     parameterValuesArray.length > 0 &&
     parameterValuesArray[0] instanceof String) {
		String reflectiveOpName = (String) parameterValuesArray[0];
		Operation refOp = ((IEolModule) module).getOperations().stream()
			.filter(op -> reflectiveOpName.equals(op.getName()))
			.findAny()
			.orElse(null);
		if (refOp != null) {
			return refOp.execute(targetObject, parameterValues.subList(1, parameterValues.size()), context);
and in EOL:
operation String foo() {
	return "foo called";
Re: Using reflection [message #1820657 is a reply to message #1820587] Sat, 25 January 2020 04:29 Go to previous messageGo to next message
Hi Sina,
If we want to add proper built-in support for calling operations reflectively I guess we should also check argument types, consider operation contributors, dot vs. arrow etc.
Dimitris
Re: Using reflection [message #1820671 is a reply to message #1820657] Sat, 25 January 2020 13:36 Go to previous messageGo to next message
Hi Dimitris,
That's a good point. I assume this would essentially mean calling OperationCallExpression.execute reflectively, rather than adding this minimal logic to OperationCallExpression itself, or at least factoring out the operation call logic. An alternative is to add some sort of "EOL Evaluator" built in to System, which operates on the current context's module. I'm wondering whether it is a worthwhile feature to have in the language or too niche of a requirement to support?
Sina
Re: Using reflection [message #1820728 is a reply to message #1820671] Mon, 27 January 2020 15:52 Go to previous messageGo to next message
Hi Sina,
Given that there's a sensible workaround, I'd be inclined to wait for a couple of similar use-cases to show up before we consider implementing this feature.
Dimitris
Re: Using reflection [message #1838211 is a reply to message #1820728] Thu, 18 February 2021 10:31 Go to previous messageGo to next message
I forgot about this discussion! Very nice! I'm already using the first solution.
Re: Using reflection [message #1838217 is a reply to message #1838211] Thu, 18 February 2021 11:32 Go to previous messageGo to next message
since we are here I couldn't get the context of an operation declaration...how is this defined?
Re: Using reflection [message #1838222 is a reply to message #1838217] Thu, 18 February 2021 13:19 Go to previous messageGo to next message
op.getContextType(System.context) should do the trick.
Dimitris
Re: Using reflection [message #1838226 is a reply to message #1838222] Thu, 18 February 2021 16:37 Go to previous message
Perfect, it works
Previous Topic:[ETL]Creating xmi file from ETL transformation output file(.model)
Next Topic:accessing runtime models with reflection
Current Time: Sun Jul 20 08:33:48 EDT 2025
Powered by FUDForum. Page generated in 0.26398 seconds
