Problem with org.eclipse.core.resources.ResourcesPlugin initialization [message #1837133] |
Fri, 22 January 2021 09:25  |
We updated our target platform from 2020-06 to the newest version.
During application startup, we now get an exception (see below) when calling:
org.eclipse.core.resources.ResourcesPlugin.getWorkspace()
We see this exception starting from release 2020-09.
Does anyone know what could be the problem?
!ENTRY org.eclipse.osgi 4 0 2021-01-22 15:21:20.536
!MESSAGE An error occurred while automatically activating bundle org.eclipse.core.resources (132).
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.core.resources.ResourcesPlugin.start() of bundle org.eclipse.core.resources.
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:835)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:763)
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:1011)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:365)
at org.eclipse.osgi.container.Module.doStart(Module.java:605)
at org.eclipse.osgi.container.Module.start(Module.java:468)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:506)
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:117)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:572)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:346)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:398)
at org.eclipse.osgi.internal.loader.sources.SingleSourcePackage.loadClass(SingleSourcePackage.java:41)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:456)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:171)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:522)
<<<< calling org.eclipse.core.resources.ResourcesPlugin.getWorkspace() >>>>
at org.eclipse.osgi.internal.framework.BundleContextImpl$2.run(BundleContextImpl.java:814)
at org.eclipse.osgi.internal.framework.BundleContextImpl$2.run(BundleContextImpl.java:1)
at java.base/java.security.AccessController.doPrivileged(Native Method)
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:806)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:477)
at org.eclipse.osgi.internal.framework.EquinoxBundle.loadClass(EquinoxBundle.java:616)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:196)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:920)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:246)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:63)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:198)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
at org.eclipse.equinox.launcher.Main.run(Main.java:1461)
at org.eclipse.equinox.launcher.Main.main(Main.java:1434)
at org.eclipse.core.internal.resources.CharsetDeltaJob.startup(CharsetDeltaJob.java:212)
at org.eclipse.core.internal.resources.CharsetManager.startup(CharsetManager.java:505)
at org.eclipse.core.internal.resources.Workspace.startup(Workspace.java:2456)
at org.eclipse.core.internal.resources.Workspace.open(Workspace.java:2210)
at org.eclipse.core.resources.ResourcesPlugin.start(ResourcesPlugin.java:489)
... 50 more
[Updated on: Fri, 22 January 2021 09:27] by Moderator
FUDForum. Page generated in 0.80816 seconds
