Edges display - Bug / Missing feature [message #1835383] |
Wed, 02 December 2020 01:32  |
I am experiencing a problem in achieving a desired behavior for edges representation my workbench. When I use an element based edge between regular nodes with "Straight" routing style, the designer (user of my workbench) can change the routing by dragging the lines, adding "bend-points". I consider this a desired behavior.
However, when the edge - with same definitions - is connected to a container instead of a regular node, the user is not able to create these bend-points, and the edge line is forced to be straight.
I am attaching a screenshot, as well as a very simple demo model to illustrate this.
Can this be opened as a bug? (so that the edge representation when using containers will allow adding bendpoints)
Is there a way to by-pass the problem and create bend-points for the container-related edges?
Thank you,
Avi
Attachment: demo1edge.png
(Size: 80.18KB, Downloaded 65 times)
Attachment: demo1.zip
(Size: 141.85KB, Downloaded 57 times)
[Updated on: Wed, 02 December 2020 01:33] by Moderator
FUDForum. Page generated in 0.06730 seconds
