Home » Eclipse Projects » Eclipse Titan » OpenSSL 1.1.1.g not supported(TITAN OpenSSL)
OpenSSL 1.1.1.g not supported [message #1833028] Thu, 01 October 2020 02:23 Go to next message
I just updated OpenSSL from version 1.1.1 (Sept 2018) to 1.1.1g (Apr 2020).
When I compile TITAN from scratch, I got the following errors:
Int.o: In function `Common::int_val_t::operator-() const':
Int.cc:(.text+0x4c0): undefined reference to `BN_is_negative'
Int.o: In function `Common::int_val_t::operator-(Common::int_val_t const&) const':
Int.cc:(.text+0x9b9): undefined reference to `BN_is_negative'
Int.cc:(.text+0x9d1): undefined reference to `BN_is_negative'
Int.o: In function `Common::int_val_t::operator+(Common::int_val_t const&) const':
Int.cc:(.text+0xcb9): undefined reference to `BN_is_negative'
Int.cc:(.text+0xcd1): undefined reference to `BN_is_negative'
Int.o:Int.cc:(.text+0x159b): more undefined references to `BN_is_negative' follow
../common/openssl_version.o: In function `openssl_version_str':
openssl_version.c:(.text+0x3): undefined reference to `OpenSSL_version'
What is the lastest OpenSSL version supported by TITAN?
Thanks a lot,
Best Reagrds,
Yann
Re: OpenSSL 1.1.1.g not supported [message #1833030 is a reply to message #1833028] Thu, 01 October 2020 02:31 Go to previous messageGo to next message
Are you sure that the correct header files were used during the compilation?
The 1.1.1 (Sept 2018) and 1.1.1g (Apr 2020) are ABI compatible, so no recompilation is needed to use the newer libraries.
The error message indicates that the object file were compiled with the header files of the 1.0.1 or older but try to link with 1.1.0 or newer
Re: OpenSSL 1.1.1.g not supported [message #1833031 is a reply to message #1833030] Thu, 01 October 2020 02:58 Go to previous messageGo to next message
Hello Gabor,
Yes, I'm sure:
yann@Linux:~/dev/TTF0002_Its/scripts$ grep -i OPENSSL_VERSION_TEXT /usr/include/openssl/opensslv.h
# define OPENSSL_VERSION_TEXT "OpenSSL 1.1.1g 21 Apr 2020"
Yann
Re: OpenSSL 1.1.1.g not supported [message #1833034 is a reply to message #1833031] Thu, 01 October 2020 03:32 Go to previous message
Hello Gabor,
I found the issue: the links to the share libraries libssl.so and libcrypto.so were not updated by the 'sudo make install' command from openssl1.1.1g.
My apologies for the inconveniences,
Yann
Previous Topic:Request for an actual SUT with its TTCN-3 tests
Next Topic:Wrong decoding of matched / unmatched messages paths in log files
Current Time: Sun Jul 20 08:46:52 EDT 2025
Powered by FUDForum. Page generated in 0.24766 seconds
