Home » Eclipse Projects » Sirius » References not showing from horizontal stack containers(References not showing from horizontal stack containers)
References not showing from horizontal stack containers [message #1832346] Wed, 16 September 2020 16:07 Go to next message
I am trying to develop an editor and trying to explore ways to make my containers collapsible. I realized that horizontal and vertical stack are capable of this. However, when I set my container to horizontal stack all of my references no longer show up graphically in the editor, but when I use the vertical one they do. Is there a reason for this or is this a bug? And is there a way to have the references show up when I use horizontal stack for my containers??
I can't really use vertical stack because then it makes the model look unintelligible so I would like to use horizontal stack if at all possible!
Re: References not showing from horizontal stack containers [message #1832358 is a reply to message #1832346] Thu, 17 September 2020 02:14 Go to previous messageGo to next message
It's difficult to be sure, but from your description it sounds similar to https://bugs.eclipse.org/bugs/show_bug.cgi?id=543946. Could you confirm?
We have a rough idea of the cause and fix, but not the resources at the moment to fix it properly. It's on our radar, but I can't guarantee when a fix will be available.
Pierre-Charles
Re: References not showing from horizontal stack containers [message #1832717 is a reply to message #1832358] Wed, 23 September 2020 16:13 Go to previous messageGo to next message
Hi Pierre,
The link that you sent takes me to a page that says the following: '543946.' is not a valid bug number nor an alias to a bug.
I have discovered that if I move my model around though that vertical stack will only show references vertically and horizontal stack will only show references horizontally. I don't get any error or warning codes about it so I'm not sure how I can confirm if it is the bug that you have listed.
Tom
Re: References not showing from horizontal stack containers [message #1832865 is a reply to message #1832717] Mon, 28 September 2020 03:10 Go to previous messageGo to next message
There is a "." at the end of Pierre-Charles's URL. The real URL is just https://bugs.eclipse.org/bugs/show_bug.cgi?id=543946
Re: References not showing from horizontal stack containers [message #1832942 is a reply to message #1832865] Tue, 29 September 2020 12:48 Go to previous message
Yes it appears to be the same bug that is described in the link. The description matches the behavior that I have in my editor.
Previous Topic:Trying to define Relation Based Edges
Next Topic:Element Based Edge Creation Tool
Current Time: Sun Jul 20 13:17:08 EDT 2025
Powered by FUDForum. Page generated in 0.04106 seconds
