Home » Language IDEs » C / C++ IDE (CDT) » Edit source lookup path options are not working
Edit source lookup path options are not working [message #1832686] Wed, 23 September 2020 07:08 Go to next message
i have tried to Edit the source lookup path but none of the container options are not working , did eclipse CDT deprecate+ any of these options ?
  • Attachment: CDT FORUM.png
    (Size: 157.49KB, Downloaded 93 times)
[Updated on: Wed, 23 September 2020 17:33] by Moderator
Re: Edit source lookup path options are not working [message #1832790 is a reply to message #1832686] Fri, 25 September 2020 03:22 Go to previous messageGo to next message
They work for me.
Perhaps a little more context is needed.
Why do you think they aren't working?
Re: Edit source lookup path options are not working [message #1832853 is a reply to message #1832790] Sun, 27 September 2020 10:15 Go to previous messageGo to next message
when i tried to run it from the product when I map the source file using any of these container its not detecting the source code.
Re: Edit source lookup path options are not working [message #1832858 is a reply to message #1832853] Sun, 27 September 2020 22:06 Go to previous message
Without more specific information it isn't possible to help you.
Understand that although the dialog says "container" it isn't referring to something like a Docker container.
It should have said "path type" or similar.
Perhaps reading what gdb does to find the source may help.
The following may be for an earlier version of gdb but it hasn't changed:
https://sourceware.org/gdb/onlinedocs/gdb/Source-Path.html
https://ftp.gnu.org/old-gnu/Manuals/gdb/html_node/gdb_48.html
[Updated on: Sun, 27 September 2020 22:13] by Moderator
Previous Topic:Assembly instruction 'sr'
Next Topic:Ignoring multiline assembler blocks
Current Time: Sun Jul 20 03:07:05 EDT 2025
Powered by FUDForum. Page generated in 0.03452 seconds
