Home » Language IDEs » C / C++ IDE (CDT) » use mingw32-make.exe intead of make
use mingw32-make.exe intead of make [message #1832418] Thu, 17 September 2020 10:19 Go to next message
I need eclipse to run "mingw32-make.exe" intead of "make" on a particular build system. I see where I can edit the PATH but that won't help. How can I specify that the binary for make is "mingw32-make.exe" on that system?
edit:
Eclipse IDE for C/C++ Developers
Version: 2020-03 (4.15.0)
Build id: 20200313-1211
[Updated on: Thu, 17 September 2020 10:45] by Moderator
Re: use mingw32-make.exe intead of make [message #1832448 is a reply to message #1832418] Fri, 18 September 2020 03:49 Go to previous messageGo to next message
Change the build command.
Project --> Properties --> C/C++ Build --> Builder Settings tab --> Build Command
[Updated on: Fri, 18 September 2020 03:50] by Moderator
Re: use mingw32-make.exe intead of make [message #1832451 is a reply to message #1832448] Fri, 18 September 2020 04:50 Go to previous message
Thanks for the help David, I didn't see that.
Previous Topic:How to get ICProject out of IProject?
Next Topic:Make file
Current Time: Sun Jul 20 09:06:33 EDT 2025
Powered by FUDForum. Page generated in 0.06512 seconds
