Home » Modeling » TMF (Xtext) » Unresolved reference with dsl in jar library
Unresolved reference with dsl in jar library [message #1832404] Thu, 17 September 2020 09:28 Go to next message
I am trying to put default types of my dsl in a separate plugin.
My dsl is based on theTerminal grammar and does not used xbase.
I created a "Default" plugin with defaults.myDsl which contains all basics types I need.
My others project have a dependency in their Manifest on "Default" plugin.
I can reference types from "Default" without any pb when the "Default" plugin is opened in the current workspace.
Now I would like to put "Default" in a jar library. I exported the plugin to a fragment and installed it in my eclipse. In the plugin dependency of my projects, the "Default" plugin is found and contains the file defaults.myDsl.
My problem is that references are not resolved, it seems that "Default" plugin is not visible by xtext.
Do you have any idea how to resolve this pb ?
Yannick
Re: Unresolved reference with dsl in jar library [message #1832405 is a reply to message #1832404] Thu, 17 September 2020 09:31 Go to previous messageGo to next message
I used the following tuto :
https://nittka.github.io/2011/08/07/scoping3.html
Yannick
Re: Unresolved reference with dsl in jar library [message #1832407 is a reply to message #1832405] Thu, 17 September 2020 09:33 Go to previous messageGo to next message
did you put your stuff to the classpath of the project that fails to resolve the references
Re: Unresolved reference with dsl in jar library [message #1832409 is a reply to message #1832407] Thu, 17 September 2020 09:41 Go to previous messageGo to next message
The clasppath contains
<classpath>
	<classpathentry kind="con" path="org.eclipse.jdt.launching.JRE_CONTAINER/org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType/JavaSE-1.8"/>
	<classpathentry kind="con" path="org.eclipse.pde.core.requiredPlugins"/>
	<classpathentry kind="src" path="src"/>
	<classpathentry kind="output" path="bin"/>
</classpath>
I think that the org.eclipse.pde.core.requiredPlugin should resolve the plugin location.
In the Plug-in dependencies of the project, the "Default" plugin is present and contains defaults.myDsl.
Yannick
Re: Unresolved reference with dsl in jar library [message #1832411 is a reply to message #1832409] Thu, 17 September 2020 09:48 Go to previous messageGo to next message
how does the requiredPlugins container in package explorer look like?
does it contain the mydsl file? can you share a screenshot?
Re: Unresolved reference with dsl in jar library [message #1832413 is a reply to message #1832411] Thu, 17 September 2020 09:56 Go to previous messageGo to next message
Sorry, I can't share screenshot.
In the case the Default plugin is opened in the current workspace, the StateBasedContainerManager#getVisibleContainers returns list of handles [Default,Test]
In the case the Default plugin is a jar plugin I have only [Test]. I continue my investigation with the debugger.
Yannick
Re: Unresolved reference with dsl in jar library [message #1832415 is a reply to message #1832413] Thu, 17 September 2020 10:06 Go to previous messageGo to next message
In the case the Default plugin is not resolved, it's because the project is not accessible:
XtextProjectHelper#hasNature
--> project.isAccessible() --> returns false
so the Default project is closed.
This project contains only a myDsl file.
Yannick
Re: Unresolved reference with dsl in jar library [message #1832416 is a reply to message #1832413] Thu, 17 September 2020 10:18 Go to previous messageGo to next message
does it look the same for you?
index.php/fa/38924/0/
Re: Unresolved reference with dsl in jar library [message #1832417 is a reply to message #1832416] Thu, 17 September 2020 10:18 Go to previous messageGo to next message
why is project closed?
Re: Unresolved reference with dsl in jar library [message #1832419 is a reply to message #1832417] Thu, 17 September 2020 10:26 Go to previous messageGo to next message
Yes it looks the same.
I don't know why the project is closed.
Thanks for your help. I continue to investigate.
Yannick
[SOLVED] Re: Unresolved reference with dsl in jar library [message #1832427 is a reply to message #1832419] Thu, 17 September 2020 13:30 Go to previous message
The problem is resolved !
There was an error in my ui Module. I was using the SimpleResourceSetProvider instead of the XtextResourceSetProvider (by default).
Yannick
Previous Topic: generator denies to run
Next Topic:Xtend template expressions are not resolved using Xtend Maven plugin
Current Time: Sat Jul 19 19:06:28 EDT 2025
Powered by FUDForum. Page generated in 0.08181 seconds
