Home » Eclipse Projects » Oomph » Installer opens website to install Java
Installer opens website to install Java [message #1832027] Sun, 06 September 2020 05:49 Go to next message
I ran the installer without a JRE installed, so I installed Oracle JRE 8.. Now, when I run it again, it opens a website, proposing to download a selection of Javas. How can I ask it to try again with the Java on the system?
Felix
Re: Installer opens website to install Java [message #1832030 is a reply to message #1832027] Sun, 06 September 2020 11:51 Go to previous messageGo to next message
You're sure you installed a 64 bit version of Java? Where exactly is your Java installed on your machine? Of course running the installer again will again look at what's installed on your system. Is this on Windows?
This installer contains a JRE:
https://www.eclipse.org/downloads/download.php?file=/oomph/products/eclipse-inst-jre-win64.exe
And then you can choose which JRE is used by your installation (which also let's you review which JREs are known on your operating system).
Re: Installer opens website to install Java [message #1832033 is a reply to message #1832030] Sun, 06 September 2020 16:49 Go to previous messageGo to next message
Maybe not quite sure. I lost it this morning when I had to create an Oracle User Account to download a JDK.. I then downloaded something from https://www.java.com/en/download/win10.jsp, I assumed by now everything is 64 and didn't even care to check. Haha, in my face. Is this installer you linked made with the JustJ project?
Re: Installer opens website to install Java [message #1832034 is a reply to message #1832033] Mon, 07 September 2020 02:47 Go to previous message
That looks like 64 bit. Yes, that installer uses a JRE built by the JustJ project. The installer looks in the system registry for Java installations and tests the ones it finds for version and bitness. Perhaps it doesn't find it because Oracle changed yet again the key where it's stored...
Previous Topic:Looking for a Mylyn-free oomph configuration
Next Topic:Creating linked projects/products (href) using the setup model editor
Current Time: Sun Jul 20 19:00:31 EDT 2025
Powered by FUDForum. Page generated in 0.04456 seconds
