Home » Modeling » TMF (Xtext) » How to get the 'Name/ID' of any EObject in the workspace
How to get the 'Name/ID' of any EObject in the workspace [message #1831969] Fri, 04 September 2020 01:03 Go to next message
Hi Members,
I have a DSL which refers to EObjects of any other DSL instances inthe workspace. The grammar is something like below.
Template:
	'Name' ID'.'
	'Import' imports+= [ecore::EObject|ID] '.'
The imports refer to all the EObjects in the runtime workspace , where all these EOBjects can come from various other DSLs.
The DSL instance is like
	Name MyTemplate
	Import  ObjectInstanceNameFromOtherDSL
Now the assumption here is that every Eobject will have a name or an ID. I want to extract that name and ID or the EObject (referred in my Template DSL) so that I could process the name and the type of the EObject. In other words in my backend (Generator) I need the EObject name
Is it possible to get the name of the EObject instances ObjectInstanceNameFromOtherDSL.
Any leads on how this should be doable ? Also request the members to please give some sample code.
Amar
[Updated on: Fri, 04 September 2020 01:44] by Moderator
Re: How to get the 'Name/ID' of any EObject in the workspace [message #1831971 is a reply to message #1831969] Fri, 04 September 2020 02:06 Go to previous messageGo to next message
first you should change the grammar to
Template:
	'Name' ID'.'
	'Import' imports+= [ecore::EObject|FQN] '.'
FQN: ID ("." ID)*;
to also cover the names.
for extraction you can do two things.
- use the node model to read the text for the reference with org.eclipse.xtext.nodemodel.util.NodeModelUtils.findNodesForFeature(EObject, EStructuralFeature) (in this case it would be easier to have single valued references (no +=)
- use emf reflection api to get the value (org.eclipse.emf.ecore.EObject.eGet(EStructuralFeature) + org.eclipse.emf.ecore.EObject.eClass() + org.eclipse.emf.ecore.EClass.getEStructuralFeature(String))
Re: How to get the 'Name/ID' of any EObject in the workspace [message #1831972 is a reply to message #1831971] Fri, 04 September 2020 02:21 Go to previous messageGo to next message
Thanks a lot Christian.
Can you also please suggest how to implement this. As I am fairly new to EMF and Xtext I am not able to fully understand the code.
To implement
NodeModelUtils.findNodesForFeature(eobj, estrfeature)
The eobj is the object Reffered EObject right ? and How do I get the estrfeature object ?
Also I didnt quite understand
Could you please explain this.
Thanks again,
Amar
Re: How to get the 'Name/ID' of any EObject in the workspace [message #1831979 is a reply to message #1831972] Fri, 04 September 2020 03:56 Go to previous messageGo to next message
org.eclipse.emf.ecore.EObject.eClass() gives you the eclass of the eobject
org.eclipse.emf.ecore.EClass.getEStructuralFeature(String) allows you to the the name feature
org.eclipse.emf.ecore.EObject.eGet(EStructuralFeature) allows you to get the value of the name feature
NodeModelUtils.findNodesForFeature(myTemplateObject, MyDslPackage.Literals.TEMPLATE__IMPORTS) (am not sure if _ or __ will give you a list of nodes, which you can ask for text (searching for it will reveal examples)
Re: How to get the 'Name/ID' of any EObject in the workspace [message #1831987 is a reply to message #1831979] Fri, 04 September 2020 04:50 Go to previous messageGo to next message
Hi Christian,
I tried this
def getEObjectName(EObject eObj) {
               println("EObject::"+eObj)
		var eClass = eObj.eClass
		var structuralFeature = eClass.getEStructuralFeature("name")
		var name = eObj.eGet(structuralFeature) as EObject
		println("Name::"+name)
However the result is
EObject::com.YDL.impl.NameImpl@20e772af (function: false)
Name::com.YDL.impl.NameImpl@20e772af (function: false)
Seems that both the obsjects resturn the same value.
The NameImp comes from another DSL and has an attribute 'name'.
Any guess, what I might be doing wrong ?
Amar
[Updated on: Fri, 04 September 2020 04:53] by Moderator
Re: How to get the 'Name/ID' of any EObject in the workspace [message #1831988 is a reply to message #1831987] Fri, 04 September 2020 05:04 Go to previous messageGo to next message
then your stuff does not hold this statement true
cause it has a name object
(you can check if the result from get is a eobject and if yes you can do the get structural feature stuff again)
[Updated on: Fri, 04 September 2020 05:05] by Moderator
Re: How to get the 'Name/ID' of any EObject in the workspace [message #1831994 is a reply to message #1831988] Fri, 04 September 2020 06:04 Go to previous messageGo to next message
*Update*
println("Name::" + name)
for (node : getNodes(name)) {
			println("NODE::" + node.text + "  SEMANTIC CLASS::" + node.semanticElement)
the type of structuralFeature shows as
org.eclipse.emf.ecore.impl.EReferenceImpl@20271a5b (name: name) (ordered: true, unique: true, lowerBound: 0, upperBound: 1) (changeable: true, volatile: false, transient: false, defaultValueLiteral: null, unsettable: false, derived: false) (containment: false, resolveProxies: true)
Is this desirable ?? Any thoughts ??
Amar
Re: How to get the 'Name/ID' of any EObject in the workspace [message #1831997 is a reply to message #1831994] Fri, 04 September 2020 06:55 Go to previous messageGo to next message
do you have names that are references themselves?
Re: How to get the 'Name/ID' of any EObject in the workspace [message #1831999 is a reply to message #1831997] Fri, 04 September 2020 07:06 Go to previous message
Hi Christian,
Finally solved this. Thanks to your and Ed's(From the EMF forum) guidance.
The working code is
			println("EObject::" + eObj)
			var nodes = NodeModelUtils.findNodesForFeature(eObj, structuralFeature)
			for (node : nodes) {
				if (node.semanticElement.equals(eObj)){
					println("NODE TEXT::"+node.text.trim)
					return node.text.trim
Amar
Previous Topic:Xtext / Xtend 2.23 release
Next Topic:Problems with linking in Xtext unit testing with multiple DSLs
Current Time: Sat Jul 19 12:39:17 EDT 2025
Powered by FUDForum. Page generated in 0.05069 seconds
