Home » Polarsys » Capella General » XHTML Documentation Generation and Filtering Add on (Generate partial documentation because of filtering)
XHTML Documentation Generation and Filtering Add on [message #1828919] Mon, 22 June 2020 08:14 Go to next message
I use the add on Filtering (filtering criterion) to mark / tag specific entities, diagramms, ... . All entities marked with the same filtering criterion is then a feature, relying on specific requirements.
Now I want do generate a documentation, where only the content marked with the filter criterion is documented.
I would like to use XHTML, but it seems there is no way to select a filtering criterion to generate the documentation.
Do I miss somethting and it is indeed possible?
Is there any way to extend the XHTML add on with this feature?
Does M2DOC get the job done?
Re: XHTML Documentation Generation and Filtering Add on [message #1828923 is a reply to message #1828919] Mon, 22 June 2020 08:45 Go to previous messageGo to next message
Hello Marcel,
I would recommend you to generate a new model with the filtering add-on which will filter out all the non-relevant model elements.
Then you can generate documentation from this new model :)
Re: XHTML Documentation Generation and Filtering Add on [message #1828926 is a reply to message #1828923] Mon, 22 June 2020 09:39 Go to previous messageGo to next message
Indeed, thats possible ... but not a fine and solution. Thanks.
Re: XHTML Documentation Generation and Filtering Add on [message #1828969 is a reply to message #1828926] Tue, 23 June 2020 08:24 Go to previous messageGo to next message
I guess that M2Doc is able to generate what you expect. I think that you can add an if statement to validate the existance of the filetring criteria.
Re: XHTML Documentation Generation and Filtering Add on [message #1829033 is a reply to message #1828969] Wed, 24 June 2020 04:18 Go to previous message
Still another solution is to extend the capabilities of the XHTML export to consider filters. After all, it's open source.
Previous Topic:Capella problem
Next Topic:Create Libraries from existing project RECs maintaining REC/RPL link
Current Time: Sun Jul 20 12:05:56 EDT 2025
Powered by FUDForum. Page generated in 0.05075 seconds
