Home » Eclipse Projects » EGit / JGit » Disable eGit Logging output(how to disable the logging output of egit for other plugin developers)
Disable eGit Logging output [message #1828860] Sat, 20 June 2020 03:47 Go to next message
can you make me a pleasure and please deactivate the egit logging then distributed.
Or please tell me how to deactivate the logging output of egit.
I'm a plugin developer, too, and then I develop my plugin 99% of the logging output comes from egit and only 1% of the logging output is generated from my plugin during development time.
I have also to reformat my logging output to find my log messages in the console.
As you can see in the attached file, your log level is set to DEBUG.
Best Regards
Jan
  • Attachment: console.log
    (Size: 464.11KB, Downloaded 142 times)
Re: Disable eGit Logging output [message #1828877 is a reply to message #1828860] Sat, 20 June 2020 15:34 Go to previous messageGo to next message
EGit logs via the Eclipse logging framework. What you see is the logging from JGit. JGit does not set the logging level; this is set in your logging configuration. Perhaps you have a root logger set to debug?
Re: Disable eGit Logging output [message #1829013 is a reply to message #1828877] Tue, 23 June 2020 19:28 Go to previous messageGo to next message
JGit uses the slf4j logging API but doesn't install a logging implementation on its own.
Change configuration of the logging implementation you use and set severity for loggers org.eclipse.jgit.* to the level you are interested in.
Re: Disable eGit Logging output [message #1829014 is a reply to message #1829013] Tue, 23 June 2020 19:30 Go to previous messageGo to next message
e.g. for log4j:
log4j.appender.stderr=org.apache.log4j.ConsoleAppender
log4j.appender.stderr.Target=System.err
log4j.appender.stderr.layout=org.apache.log4j.PatternLayout
log4j.appender.stderr.layout.ConversionPattern=%d{yyyy-MM-dd HH:mm:ss} %-5p %c{1}:%L - %m%n
# root logger for jgit
log4j.logger.org.eclipse.jgit = ERROR
Re: Disable eGit Logging output [message #1834416 is a reply to message #1829014] Mon, 09 November 2020 21:49 Go to previous messageGo to next message
which file to configure ?
Re: Disable eGit Logging output [message #1834535 is a reply to message #1834416] Wed, 11 November 2020 20:13 Go to previous message
for log4j configuration see https://logging.apache.org/log4j/1.2/manual.html
Previous Topic:Default Branch Name
Next Topic:GIT Versions supported
Current Time: Sun Jul 20 12:51:43 EDT 2025
Powered by FUDForum. Page generated in 0.04315 seconds
