Home » Language IDEs » C / C++ IDE (CDT) » Code block editing (editor )
Code block editing [message #1827762] Fri, 22 May 2020 13:26 Go to next message
While using Eclipse editor one can highlight a code block between curly brackets
{ // code block
} // code block
using mouse.
Is there a similar way to highlight code in preprocessor block ?
#ifdef CODEBLOCK
#endif
At some point the code block between preprocessor directives was "highlighted" by different background color.
That "feature " no longer works in 2020-03
Re: Code block editing [message #1828402 is a reply to message #1827762] Tue, 09 June 2020 04:56 Go to previous messageGo to next message
Please I have a problem. I have successfully installed eclipse and mingw and ran the hello world program. However I create a new project and bring up an editor window
Re: Code block editing [message #1828442 is a reply to message #1828402] Tue, 09 June 2020 14:31 Go to previous messageGo to next message
Please do not post a completely unrelated question to a previous thread.
To your question: Open the Eclipse help for C/C++ Development Toolkit (CDT) and read it. The instructions are there.
Re: Code block editing [message #1828542 is a reply to message #1828442] Thu, 11 June 2020 12:48 Go to previous messageGo to next message
Tauno ,
if you actually read the post you COULD see it was not completed .
All YOUR remark did is created unnecessary e-mail traffic.
Please - let it slide in future , or stick to the original post and contribute with real answer instead of cluttering things with superficial "administration".
Re: Code block editing [message #1828550 is a reply to message #1828542] Thu, 11 June 2020 14:50 Go to previous message
The onlu coloring I have seen on preprocessor directives is when the part of the code is not active, see attached image.
index.php/fa/38319/0/
  • Attachment: Colors.png
    (Size: 13.36KB, Downloaded 288 times)
Previous Topic:Indexer not finding symbol 'SCB->CCR'
Next Topic:float type works with Keil but not with Eclipse
Current Time: Sun Jul 20 14:18:13 EDT 2025
Powered by FUDForum. Page generated in 0.06408 seconds
