Direct edit label throws ClassCastException [message #1828539] |
Thu, 11 June 2020 11:23  |
I have a node, of which I'm trying to create an edit label tool that will modify its name.
But I'm getting this error upon starting up the runtime environment.
I thought it was a bug with my Sirius version so I upgraded from Obeo Community 11.1 to 11.3, which integrates with Sirius 6.3 but it did not solve the problem.
Quote:org.eclipse.emf.ecore.xmi.IllegalValueException: Value 'org.eclipse.sirius.diagram.description.tool.impl.NodeCreationDescriptionImpl@7bf3bf2e (documentation: ) (name: Activity, label: null, precondition: , forceRefresh: false, elementsToSelect: , inverseSelectionOrder: false) (iconPath: )' is not legal. (platform:/plugin/viewpoint.supervisory.design/description/supervisory.odesign, -1, -1)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XMLHandler.java:2715)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleForwardReferences(XMLHandler.java:1193)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.endDocument(XMLHandler.java:1282)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.endDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:175)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:261)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1563)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1342)
at org.eclipse.sirius.viewpoint.description.util.DescriptionResourceImpl.load(DescriptionResourceImpl.java:99)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:259)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:406)
at org.eclipse.sirius.business.internal.componentization.ViewpointRegistryImpl.load(ViewpointRegistryImpl.java:692)
at org.eclipse.sirius.business.internal.componentization.ViewpointRegistryImpl.registerFromPlugin(ViewpointRegistryImpl.java:335)
at viewpoint.supervisory.design.Activator.start(Activator.java:38)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:842)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:834)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:791)
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:1013)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:365)
at org.eclipse.osgi.container.Module.doStart(Module.java:598)
at org.eclipse.osgi.container.Module.start(Module.java:462)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:493)
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:117)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:570)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:330)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:396)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:474)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:423)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:415)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:155)
at org.eclipse.osgi.internal.framework.EquinoxBundle.loadClass(EquinoxBundle.java:620)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:196)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:934)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:246)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:63)
at org.eclipse.sirius.common.tools.api.util.EclipseUtil.getExtensionPlugins(EclipseUtil.java:139)
at org.eclipse.sirius.common.tools.api.util.EclipseUtil.getExtensionPlugins(EclipseUtil.java:82)
at org.eclipse.sirius.business.internal.componentization.ViewpointRegistryImpl.initViewpointsFromPlugins(ViewpointRegistryImpl.java:709)
at org.eclipse.sirius.business.internal.componentization.ViewpointRegistryImpl.init(ViewpointRegistryImpl.java:194)
at org.eclipse.sirius.business.api.componentization.ViewpointRegistry$ViewpointRegistryHolder.<clinit>(ViewpointRegistry.java:137)
at org.eclipse.sirius.business.api.componentization.ViewpointRegistry.getInstance(ViewpointRegistry.java:123)
at org.eclipse.emf.ecoretools.design.service.EcoreToolsDesignPlugin$Implementation.start(EcoreToolsDesignPlugin.java:123)
at org.eclipse.sirius.business.internal.session.SessionManagerImpl.getExtensionPointListeners(SessionManagerImpl.java:379)
at org.eclipse.sirius.business.internal.session.SessionManagerImpl.getAllListeners(SessionManagerImpl.java:368)
at org.eclipse.sirius.business.internal.session.SessionManagerImpl.add(SessionManagerImpl.java:141)
at org.eclipse.sirius.business.internal.session.danalysis.DAnalysisSessionImpl.open(DAnalysisSessionImpl.java:1348)
at org.eclipse.sirius.business.internal.session.SessionManagerImpl.openSession(SessionManagerImpl.java:396)
at org.eclipse.sirius.ui.business.api.session.SessionEditorInput.openSession(SessionEditorInput.java:285)
at org.eclipse.sirius.ui.business.api.session.SessionEditorInput.getSession(SessionEditorInput.java:265)
at org.eclipse.sirius.ui.business.api.session.SessionEditorInput.getSession(SessionEditorInput.java:238)
at org.eclipse.sirius.ui.business.api.session.SessionEditorInput.loadState(SessionEditorInput.java:218)
at org.eclipse.emf.common.ui.URIEditorInput.<init>(URIEditorInput.java:54)
at org.eclipse.sirius.ui.business.api.session.SessionEditorInput.<init>(SessionEditorInput.java:112)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at org.eclipse.emf.common.ui.URIEditorInput.create(URIEditorInput.java:170)
at org.eclipse.emf.common.ui.URIEditorInputFactory.createElement(URIEditorInputFactory.java:33)
at org.eclipse.sirius.ui.business.api.session.SessionEditorInputFactory.createElement(SessionEditorInputFactory.java:53)
at org.eclipse.ui.internal.EditorReference.createInput(EditorReference.java:270)
at org.eclipse.ui.internal.EditorReference.restoreInput(EditorReference.java:244)
at org.eclipse.ui.internal.EditorReference.getEditorInput(EditorReference.java:301)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor.createPart(CompatibilityEditor.java:67)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:338)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:58)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:1001)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:966)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalInject(InjectorImpl.java:139)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:411)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:333)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:202)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:91)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:60)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:42)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:132)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:1015)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:675)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:781)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:752)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:746)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:45)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:730)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1294)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:105)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:693)
at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:72)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:689)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$1.run(PartRenderingEngine.java:560)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:544)
at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.createWidget(ElementReferenceRenderer.java:73)
at org.eclipse.e4.ui.workbench.renderers.swt.SashRenderer.processContents(SashRenderer.java:140)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(PerspectiveRenderer.java:51)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:82)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.postProcess(PerspectiveStackRenderer.java:64)
at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:665)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1099)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:338)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1062)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:155)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:635)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:559)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:155)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:660)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:597)
at org.eclipse.equinox.launcher.Main.run(Main.java:1468)
at org.eclipse.equinox.launcher.Main.main(Main.java:1441)
Caused by: java.lang.ClassCastException: org.eclipse.sirius.diagram.description.tool.impl.NodeCreationDescriptionImpl cannot be cast to org.eclipse.sirius.diagram.description.tool.DirectEditLabel
at org.eclipse.sirius.diagram.description.impl.DiagramElementMappingImpl.eSet(DiagramElementMappingImpl.java:604)
at org.eclipse.sirius.diagram.description.impl.AbstractNodeMappingImpl.eSet(AbstractNodeMappingImpl.java:277)
at org.eclipse.sirius.diagram.description.impl.NodeMappingImpl.eSet(NodeMappingImpl.java:263)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet(BasicEObjectImpl.java:1071)
at org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.setValue(XMLHelperImpl.java:1204)
at org.eclipse.sirius.business.internal.migration.description.VSMXMIHelper.setValue(VSMXMIHelper.java:60)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XMLHandler.java:2710)
... 215 more
Re: Direct edit label throws ClassCastException [message #1828664 is a reply to message #1828539] |
Tue, 16 June 2020 04:40  |
I do not see the whole structure of your odesign in your screenshot, but based on it I would recommand to move the Edition tool, in a tool section under the same layer (here default) as the mapping. Can you tell us what is the parent of your current Edition tool? I have not been able to reproduce this issue.
Steve
FUDForum. Page generated in 0.03360 seconds
