Home » Modeling » EMF » Error log interpretation
Error log interpretation [message #1827731] Thu, 21 May 2020 18:36 Go to next message
Hi there!
I've developed a modelling workbench using EuGENia and everything works fine when I run my .eugenia folder as an Eclipse Application from the Eclipse workbench of my machine A.
However, when I load the same set of folders on another machine (machine B) and try to do the same as above, it doesn't work out, as per the attached error log file.
I may be missing some Eclipse configuration or installation on my machine B...Could anyone please help me figure out a solution to this problem?
Thank you for your attention.
Clever.
  • Attachment: Error Log.txt
    (Size: 17.93KB, Downloaded 122 times)
Re: Error log interpretation [message #1827748 is a reply to message #1827731] Fri, 22 May 2020 08:07 Go to previous message
Sorry, but this is not EMF related and looks to be some problem with how you've launched. I'm not sure what you copied form one machine to another, but everything needed to launch appears to be missing or mis-configured.
Previous Topic:Ecore/Genmodel override "Root Extends Interface"
Next Topic:Manage Tool Documentation
Current Time: Sun Jul 20 18:42:39 EDT 2025
Powered by FUDForum. Page generated in 0.23645 seconds
