Home » Eclipse Projects » Eclipse Platform » Disable Dark theme on macOS for eclipse products(dark theme)
Disable Dark theme on macOS for eclipse products [message #1827439] Thu, 14 May 2020 10:08 Go to next message
Is there a way through properties or other to disable the automatic dark theme selection when macOS is itself set on dark theme.
Our product has plugins that don't support dark theme so I would like the product to be on light theme even if the OS is using a dark theme.
I tried to use org.eclipse.swt.display.useSystemTheme but it did not work.
Thanks.
Re: Disable Dark theme on macOS for eclipse products [message #1827446 is a reply to message #1827439] Thu, 14 May 2020 11:35 Go to previous messageGo to next message
This should be possible by setting the cssTheme property to org.eclipse.e4.ui.css.theme.e4_default
Re: Disable Dark theme on macOS for eclipse products [message #1827535 is a reply to message #1827446] Sun, 17 May 2020 17:55 Go to previous messageGo to next message
Thanks for the answer, but I was already using this property. It seems to have no effect. If macOS is set to use dark theme, the eclipse dark theme seems to be activated by default.
Re: Disable Dark theme on macOS for eclipse products [message #1827582 is a reply to message #1827535] Mon, 18 May 2020 13:03 Go to previous messageGo to next message
I don't have macOS available, so I cannot validate. When the option is ignored when the dark OS theme is used, it sounds like a bug. You might get better feedback by creating a bug report for platform UI.
Re: Disable Dark theme on macOS for eclipse products [message #1842708 is a reply to message #1827439] Tue, 29 June 2021 08:38 Go to previous messageGo to next message
Same problem here. Setting the cssTheme does not seem to have the desired effect.
@Guillaume Hillairet Have you been able to set the Light mode?
Re: Disable Dark theme on macOS for eclipse products [message #1850056 is a reply to message #1842708] Mon, 14 February 2022 03:36 Go to previous messageGo to next message
Hi!
I have the very same situation. I've made product file and I cannot get Light theme by default. In the general settings I can switch but I haven't got any way to make it default.
I've tried:
1. Set default theme for MacOS app in Info.plist
        <key>NSRequiresAquaSystemAppearance</key>
	<true/>
2. Set programArg on launcher in product file
-cssTheme
3. Set plugin_customization.ini (It is set up correctly, because other aspect is set there)
org.eclipse.e4.ui.css.swt.theme/themeid=org.eclipse.e4.ui.css.theme.e4_default
org.eclipse.e4.ui.css.swt.theme/darkestApplied=false
org.eclipse.e4.ui.css.swt.theme/enableddarkestdark=false
org.eclipse.e4.ui.workbench.renderers.swt/enableMRU=true
org.eclipse.e4.ui.workbench.renderers.swt/themeEnabled=true
3. Set cssTheme in the product extension
<property
  name="cssTheme"
  value="org.eclipse.e4.ui.css.theme.e4_default">
</property>
So I'ven't found any other suggestion in eclipse forum in this topic. I think the problem can be related that this initialization related to global config and settings first, (in the configuration directory/.settings inside the app), but I'm not confident how it works.
Re: Disable Dark theme on macOS for eclipse products [message #1856766 is a reply to message #1850056] Thu, 29 December 2022 16:22 Go to previous message
Hi - just wondered if you'd got any further with this?
Previous Topic:Change Colors for not hightlighted text in Dark Mode
Next Topic:Error during building eclipse 4.26
Current Time: Sun Jul 20 17:59:21 EDT 2025
Powered by FUDForum. Page generated in 0.03955 seconds
