How to change visibility of association member ends ? [message #1825132] |
Fri, 17 April 2020 08:59  |
I couldn't find in documentation how to change visibility of the member ends of associations in a class diagram. As shown in the joined picture, it's set to public by default, and I didn't find how to change it (to private for instance). The property tab (cf 2d joined picture) doesn't show any field or button to do that. Any hint ?
Eric
Re: How to change visibility of association member ends ? [message #1826096 is a reply to message #1826095] |
Sun, 19 April 2020 08:18   |
Hi Ed,
The "Profile" I referred to is
https://wiki.eclipse.org/Getting_Started_with_Papyrus_UMLLight
Yes, uml::NamedElement defines Visibilty. OK, then Visibilty is possible with a shared form.
Yes, even if IMHO opinion the usability of Papyrus is much better than the ones of IBM Rational Rhapsody, IBM RSA, Sparx Enterprise Architect, PTC UML Designer or VisualParadigm VisualParadigm it can be still improved.
On Papyrus useability
* Navigation is the best I have seen so far
* The magic connectors (as named by the ArchiMate specification) are fancy
* Window handling as derived from Eclipse RCP is top notch (i.e. multiple monitor support)
And functionality-wise Papyrus is IMHO far ahead of the crowd.
* model checking is the best I have seen so far
* OCL support is also the best I have seen so far (special thanks to you, Ed)
* Artifact generation (i.e. source code or office documents) is unparalleled.
* GIT support
* Source code editor support (JDT, CDT, web tools, ...)
Just to name a few.
/Carsten
Re: How to change visibility of association member ends ? [message #1827159 is a reply to message #1826212] |
Fri, 08 May 2020 10:29   |
Hi to all,
but especially to
Eric Cousin
Ed Willink
Thomas Wiman
Associations are a very special case. Being a mere line between to boxes for most UML users, reading the UML specification an uml::Association between 2 uml::Classifier elements involves at least 5 UML elements.
To start with the uml::Association itself. An uml::Association references 2..* uml::MemberEnd elements. Each uml::MemberEnd references an uml::Classifier element via type. Each uml::MemberEnd can be either owned by the uml::Association or by the uml::Classifier element it references via type. An uml::MemberEnd is an uml::Property element either being an ownedEnd or a navigableOwnedEnd when owned by an uml::Association. It is referenced via owned attribute if it is referenced by an uml::StructuredClassifier, an uml::DataType, an uml::Interface, an uml::Signal or an UML::Artifact. As a side note: Both uml::BehavioredClassifier and uml::InformationItem despite being specializations of uml::Classifier do not feature any means to own an uml::MemberEnd.
Given that uml::Association is a quite complex construct being able to mix -- using W3C XLink slang -- internal and external link nature. Given that -- and Papyrus supports that perfectly -- an uml::Association element within a model of a Papyrus project can "link" two or more uml::Classififier elements each being contained in different models in different Papyrus projects without touching the models containing the uml::Association elements. I personally use that feature quite often, as it allows to use models as libraries. The model containing the uml::Association elements assembles uml::Classifier elements (= (sub-)systems) to specify a more capable system. By not touching the models containing the sub-systems these models can be re-used in different contexts. Please refer to attached export for further information.
Back to uml::MemberEnd elements. As uml::MemberEnd elements might by owned by an uml::Association but can also be owned by an uml::Classifier element, I personally would prefer the uml::MemberEnd properties dialog to be a self-contained pop-up dialog referenced by both the uml::Association properties dialog and the uml::Classifier properties dialog.
/Carsten
EDIT example attached
Attachment: Assembly.zip
(Size: 6.36KB, Downloaded 81 times)
[Updated on: Fri, 08 May 2020 11:01] by Moderator
Re: How to change visibility of association member ends ? [message #1827208 is a reply to message #1827207] |
Sun, 10 May 2020 10:00  |
Hi Thomas,
I think we had this topic before in a different context.
In my 20+ years experience with UML the adopters I met either just wanted to draw some pictures or wanted to go MDA. So far I haven't met anyone in between.
Both are completely different markets.
The painters market is occupied by plantUML, Sparx EA and the like.
The MDA market is occupied by IBM Rational Rhapsody and Eclipse Papyrus.
There is a Papyrus UML light version. Or at least there was such an initiative. But I am only aware of the first publishing. I think it is discontinued. That Papyrus UML light aimed at the IMHO non-existent group of people in between. Nevertheless the Papyrus UML light might evolve into a simple drawing tool. Omitting all the model checks the full blown Eclipse Papyrus does. The users are only interested in getting some pictures they can drag and drop into a Word document. And I know many of them. No one of them ever seeked for more than a few paintings.
FUDForum. Page generated in 0.56590 seconds
