Home » Eclipse Projects » GEF » Multiple connections between two figures
Multiple connections between two figures [message #182515] Wed, 25 May 2005 18:18 Go to next message
Originally posted by: eri_cao_apex.yahoo.com
I want to create multiple connections between figures. It seems new
connections will overlap with old ones. I tried FanRouter that can handle
collision, but it doesn't spread connections. The code is as follows:
FanRouter router = new FanRouter();
router.setSeparation(10);
connection.setConnectionRouter(router);
I am not sure if it is the proper way to use it, or
handleCollision(PointList points, int index) has to be overrided. Is it
possible to handle mutliple connections between two figures by using
ManhattanConnectionRouter, etc.? Those connections will have different
styles or labels. Any suggestions are welcome.
Eric
Re: Multiple connections between two figures [message #182568 is a reply to message #182515] Wed, 25 May 2005 18:51 Go to previous message
You should always look at our examples before posting here. You set the
router on the connection layer, not the connection themselves. See
ShapesEditor#initializeGraphicalViewer().
"Eric Cao" <eri_cao_apex@yahoo.com> wrote in message
news:d72tpj$58r$1@news.eclipse.org...
> Eric
Previous Topic:draw2 text
Next Topic:GridLayout sample
Current Time: Sun Jul 20 19:43:50 EDT 2025
Powered by FUDForum. Page generated in 0.03917 seconds
