Home » Eclipse Projects » GEF » ReadOnly Gef
ReadOnly Gef [message #181954] Fri, 20 May 2005 07:18 Go to next message
Originally posted by: wjancz.\/\/asko.pl(change \/\/ with w)
Hi!
I have almost finished my editor. I't works great using GEF :)
Now I want to dissalow editing my diagram structure (in some cases).
I have allready block every policies and its OK.
But the problem is that there is still a palette there.
How to disable (hide) palette ?
I am using GraphicalEditorWithFlyoutPalette as my editor - is it possible to
"turn off" palette ?
I need also to block a Palette View (Window->Show View....)
Please help
...::WojT::..
Re: ReadOnly Gef [message #182136 is a reply to message #181954] Sun, 22 May 2005 18:51 Go to previous messageGo to next message
Well, since your EditPolicies are uninstalled, these palette tools would no
longer do anything anyway. But if you wanted to, you could clear out the
palette by changing its model. Remove all children from palette root. An
empty palette would still show however. You could put in a template entry
that provided a message about why the palette was empty (although that is
pretty much a hack).
"WojT" <wjancz@\/\/asko.pl(change \/\/ with w)> wrote in message
news:d6kh59$d4q$1@news.eclipse.org...
> Hi!
to
> Please help
> ..::WojT::..
Re: ReadOnly Gef [message #182229 is a reply to message #181954] Mon, 23 May 2005 16:28 Go to previous messageGo to next message
Open a feature request for this function. There is no way to block a view
from being opened in the workbench. You can close it, but what if other
editors were using it?
Instead of disbling editpolicies, you could also change the drag trackers
and the command stack to prevent editing.
> Hi!
> to "turn off" palette ?
> Please help
> ..::WojT::..
Re: ReadOnly Gef [message #182335 is a reply to message #182229] Tue, 24 May 2005 05:56 Go to previous messageGo to next message
Ok. I opened feature request: #96395.
I am waiting and looking for resolution.
Thanks.
...::WojT::..
Re: ReadOnly Gef [message #182341 is a reply to message #182335] Tue, 24 May 2005 06:06 Go to previous message
uppps :) of course for _solution_
...::WojT::..
Previous Topic:[ANN] GEF 3.1M7 is out
Next Topic:Opening menu crashes Runtime Workbench
Current Time: Sat Jul 19 06:04:20 EDT 2025
Powered by FUDForum. Page generated in 0.25629 seconds
