Home » Modeling » GMF (Graphical Modeling Framework) » New upcoming version of GMF Notation & Runtime with metamodel changes
New upcoming version of GMF Notation & Runtime with metamodel changes [message #1823247] Mon, 23 March 2020 11:34
Hi all,
This is just to inform you that I plan to release a new version of GMF Notation & Runtime 1.13.0 around mi-april [1]. Beside moving to EPL 2.0, it includes two changes that I think you should be aware of:
  • Both GMF Notation & Runtime now explicitly require Java 8. In practice this should not change anything as it was only built and tested against Eclipse versions which themselves require Java 8.
  • A new type of "Jump Link" called "Tunnel" has been added, which can produce more readable and less "visually noisy" diagrams. See the image attached in [2]. Important: this addition of a new Jump Link type, which are implemented as a enum in the GMF Notation metamodel, required a backward incompatible change. The nsURI for the GMF Notation metamodel has been changed to http://www.eclipse.org/gmf/runtime/1.0.3/notation (from 1.0.2 before). GMF 1.13 can load models from earlier versions, but the converse is not true.
This version will probably be contributed to Eclipse 2020-06.
Pierre-Charles David
[1] https://projects.eclipse.org/projects/modeling.gmf-runtime/releases/1.13.0
[2] https://bugs.eclipse.org/bugs/show_bug.cgi?id=553776
Previous Topic:Forum on Privacy and Data Protection Challenges in System Development
Next Topic:Getting view for editpartProviders context
Current Time: Sun Jul 20 19:43:34 EDT 2025
Powered by FUDForum. Page generated in 0.03405 seconds
