Home » Eclipse Projects » Sirius » Generation of ID's (How to generate ID and referencing using Eclipse Sirius?)
Generation of ID's [message #1822574] Tue, 10 March 2020 04:35 Go to next message
Good day..!!
I have used XML language in generator to create an application. Inside application i want to generate GUID and link it with other classes via references. How can i do it in generator? Is it possible to make some changes in meta-model so that it creates ID automatically?
Will be looking forward for a response.
Adil
Re: Generation of ID's [message #1822732 is a reply to message #1822574] Thu, 12 March 2020 07:13 Go to previous message
Hi Adil,
It seems your question is not related to Sirius but to a more general topic about ids in the meta-metamodels.
There are several threads on the EMF forum dealing with those aspects (among them : https://www.eclipse.org/forums/index.php/t/1085133/, https://www.eclipse.org/forums/index.php/t/241179/, https://www.eclipse.org/forums/index.php/t/214771/,...)
You will find the EMF forum here: https://www.eclipse.org/forums/index.php/f/108/
Note that you might also take a look to the EMF Book.
In you metamodel, a first lead might be to check if you have some EAttribute elements with the id property set to true.
Previous Topic:Specifying the default model object to create in new model creation
Next Topic:Rotate Diagram Element
Current Time: Sun Jul 20 19:02:33 EDT 2025
Powered by FUDForum. Page generated in 0.03561 seconds
