Home » Modeling » Papyrus » "The chosen operation is not enabled" (Designer> Generate Code )
"The chosen operation is not enabled" [message #1820770] Tue, 28 January 2020 09:18 Go to next message
I have installed the Papyrus Designer. I have created a class diagram. But when I right click and choose Designer> Generate Code I get an error message "The chosen operation is not enabled".
I have worked with the Designer previously and been able to Generate Code. Any ideas?
Re: "The chosen operation is not enabled" [message #1822711 is a reply to message #1820770] Wed, 11 March 2020 14:23 Go to previous messageGo to next message
I did ran into the same issue. I tried a lot of things to get this back working, including reinstalling Eclipse, the Papyrus main and Designer plugins. But nothing seemed to help, although I could generate code for a new project.
Finally I found out that I could resolve the issue by removing spaces from the Eclipse project name.
Maybe this helps to resolve your problem too.
Sander
Re: "The chosen operation is not enabled" [message #1822748 is a reply to message #1822711] Thu, 12 March 2020 13:22 Go to previous messageGo to next message
It sounds like the code generation plugin is missing. You can install it using the Help->Install new software... menu option.
There are several code generators. I personally use Papyrus to generate C++ code, but perhaps you want the Java generator.
Re: "The chosen operation is not enabled" [message #1823555 is a reply to message #1822748] Sat, 28 March 2020 13:22 Go to previous messageGo to next message
I can confirm that the handler code fails in case of spaces in the project name. The code checks whether the project hosting the model exists. This fails, if the obtained project name contains spaces, as they are encoded as %20. Please post a bug.
Best regards
Re: "The chosen operation is not enabled" [message #1824064 is a reply to message #1823555] Tue, 07 April 2020 06:58 Go to previous message
I've corrected this problem in the context of CDT editor improvements. It should be fixed by using a nightly build now, see update site: https://hudson.eclipse.org/papyrus/job/papyrus-designer-2019-06/lastSuccessfulBuild/artifact/releng/org.eclipse.papyrus.designer.p2/target/repository/
Previous Topic:[SysML] SI Units Library & Import
Next Topic:Problem in graphics
Current Time: Sun Jul 20 13:06:20 EDT 2025
Powered by FUDForum. Page generated in 0.24611 seconds
