Eclipse wouldn't start [message #1822565] |
Tue, 10 March 2020 01:13  |
Hi everyone,
My Eclipse used to run just fine, but after two months of holiday, it just wouldn't start. This is my .log, any advice is appreciated, thank you very much.
!SESSION 2020-03-10 18:06:54.531 -----------------------------------------------
eclipse.buildId=4.10.0.I20181206-0815
java.version=1.8.0_241
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_NZ
Framework arguments: -product org.eclipse.epp.package.java.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.java.product
!ENTRY org.eclipse.egit.core 1 0 2020-03-10 18:07:01.712
!MESSAGE Using Apache MINA sshd as ssh client.
!ENTRY org.eclipse.jface 2 0 2020-03-10 18:07:02.807
!MESSAGE Keybinding conflicts occurred. They may interfere with normal accelerator operation.
!SUBENTRY 1 org.eclipse.jface 2 0 2020-03-10 18:07:02.807
!MESSAGE A conflict occurred for CTRL+F4:
Binding(CTRL+F4,
ParameterizedCommand(Command(org.eclipse.ui.file.close,Close,
Close the active editor,
Category(org.eclipse.ui.category.file,File,null,true),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@5e584389,
,,true),null),
org.eclipse.ui.defaultAcceleratorConfiguration,
org.eclipse.ui.contexts.window,,,system)
Binding(CTRL+F4,
ParameterizedCommand(Command(org.scala.tools.eclipse.search.commands.OpenTypeHierarchy,Open Type Hierarchy,
Category(org.scala.tools.eclipse.search.commands,Search - Scala,Search - Scala,true),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@42491839,
,,true),null),
!ENTRY org.eclipse.osgi 4 0 2020-03-10 18:07:38.550
!MESSAGE Application error
!STACK 1
java.lang.OutOfMemoryError: Java heap space
at java.util.Arrays.copyOf(Unknown Source)
at java.util.ArrayList.grow(Unknown Source)
at java.util.ArrayList.ensureExplicitCapacity(Unknown Source)
at java.util.ArrayList.ensureCapacityInternal(Unknown Source)
at java.util.ArrayList.add(Unknown Source)
at org.eclipse.jface.text.TextPresentation.addStyleRange(TextPresentation.java:230)
at org.eclipse.wst.sse.ui.internal.rules.PresentationCollector.add(PresentationCollector.java:65)
at org.eclipse.wst.sse.ui.internal.provisional.style.AbstractLineStyleProvider.prepareTextRegions(AbstractLineStyleProvider.java:352)
at org.eclipse.wst.sse.ui.internal.provisional.style.AbstractLineStyleProvider.prepareRegions(AbstractLineStyleProvider.java:249)
at org.eclipse.wst.sse.ui.internal.rules.StructuredDocumentDamagerRepairer.createPresentation(StructuredDocumentDamagerRepairer.java:43)
at org.eclipse.wst.sse.ui.internal.provisional.style.StructuredPresentationReconciler.createPresentation(StructuredPresentationReconciler.java:724)
at org.eclipse.wst.sse.ui.internal.provisional.style.StructuredPresentationReconciler.processDamage(StructuredPresentationReconciler.java:870)
at org.eclipse.wst.sse.ui.internal.provisional.style.StructuredPresentationReconciler$InternalListener.inputDocumentChanged(StructuredPresentationReconciler.java:271)
at org.eclipse.wst.sse.ui.internal.provisional.style.StructuredPresentationReconciler.install(StructuredPresentationReconciler.java:600)
at org.eclipse.wst.sse.ui.internal.StructuredTextViewer.updateHighlighter(StructuredTextViewer.java:987)
at org.eclipse.wst.sse.ui.internal.StructuredTextViewer.setDocument(StructuredTextViewer.java:865)
at org.eclipse.jface.text.source.SourceViewer.setDocument(SourceViewer.java:613)
at org.eclipse.ui.texteditor.AbstractTextEditor.initializeSourceViewer(AbstractTextEditor.java:3970)
at org.eclipse.ui.texteditor.AbstractTextEditor.createPartControl(AbstractTextEditor.java:3440)
at org.eclipse.ui.texteditor.StatusTextEditor.createPartControl(StatusTextEditor.java:64)
at org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.createPartControl(AbstractDecoratedTextEditor.java:451)
at org.eclipse.wst.sse.ui.StructuredTextEditor.createPartControl(StructuredTextEditor.java:1566)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPartControl(CompatibilityPart.java:156)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor.createPartControl(CompatibilityEditor.java:102)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:367)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:58)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:1001)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:966)
!ENTRY org.eclipse.e4.ui.workbench 4 0 2020-03-10 18:07:40.304
!MESSAGE
!STACK 0
at org.eclipse.jface.resource.JFaceResources.getResources(JFaceResources.java:212)
at org.eclipse.jface.resource.JFaceResources.getResources(JFaceResources.java:230)
at org.eclipse.ui.part.WorkbenchPart.dispose(WorkbenchPart.java:103)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart.dispose(PackageExplorerPart.java:481)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.invalidate(CompatibilityPart.java:264)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.destroy(CompatibilityPart.java:424)
at org.eclipse.e4.core.internal.di.InjectorImpl.disposed(InjectorImpl.java:462)
at org.eclipse.e4.core.internal.di.Requestor.disposed(Requestor.java:159)
at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:81)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:114)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.handleInvalid(TrackableComputationExt.java:77)
at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:187)
at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:172)
at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.dispose(EclipseContextOSGi.java:102)
at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.bundleChanged(EclipseContextOSGi.java:144)
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:911)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:233)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:233)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:140)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:132)
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:194)
at org.eclipse.osgi.container.Module.publishEvent(Module.java:483)
at org.eclipse.osgi.container.Module.doStop(Module.java:641)
at org.eclipse.osgi.container.Module.stop(Module.java:505)
at org.eclipse.osgi.container.SystemModule.stop(SystemModule.java:207)
at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule$1.run(EquinoxBundle.java:213)
Re: Eclipse wouldn't start [message #1822654 is a reply to message #1822648] |
Tue, 10 March 2020 16:29  |
No, given we see this in the log:
!STACK 1
I would say it runs, but it runs out of space.
FUDForum. Page generated in 0.10552 seconds
