Home » Eclipse Projects » Sirius » Customized labels in selection wizard(Customized labels in selection wizard)
Customized labels in selection wizard [message #1821666] Tue, 18 February 2020 06:31 Go to next message
Is there a way in which the labels of the elements showing in a selection wizard can be customized?
For example, in the attached picture, I would like to show only what comes after 'Attribute Simple Type'/'Attribute Entity Type'.
Thank you!
Kind Regards,
Alexandra
  • Attachment: Capture.PNG
    (Size: 158.62KB, Downloaded 93 times)
Re: Customized labels in selection wizard [message #1821886 is a reply to message #1821666] Fri, 21 February 2020 10:42 Go to previous messageGo to next message
Hello Alexandra,
The Selection Wizard display the label returned by EMF. So if you want to change this label, you must change it in EMF.
You can modify this label in the 'Object'ItemProvider in the sources of Metamodel.edit in the package * .provider
Re: Customized labels in selection wizard [message #1821987 is a reply to message #1821886] Tue, 25 February 2020 03:54 Go to previous message
Hello Julien,
Works like a charm. Thank you very much! :)
Alexandra
Previous Topic:Tables representations
Next Topic:Integrate Xtext editor in Sirius Properties
Current Time: Sun Jul 20 15:20:25 EDT 2025
Powered by FUDForum. Page generated in 0.03926 seconds
