Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [ECP] Model Explorer e4
[ECP] Model Explorer e4 [message #1691297] Sat, 04 April 2015 17:58 Go to next message
Hello!
I would like to test ECP in an E4 application. The section in "Getting started with the EMF Client Platform" states, that to run the demo application I should use "org.eclipse.emf.ecp.application.e4.product" as my product and the feature "org.eclipse.emf.ecp.demo.e4.feature". Both are missing on my installation (Eclipse Modelling Edition w/ update to 1.5.1). Did my installation go wrong?
Second point: If I could use the demo application (e4 missing, too) as a base for my custom application, how could I display ECP's Model Explorer in my parts?
Thank you!
GV
Re: [ECP] Model Explorer e4 [message #1691379 is a reply to message #1691297] Mon, 06 April 2015 15:14 Go to previous messageGo to next message
short question, before I have a look: Which Eclipse IDE version are you
using?
Best regards
Jonas
Am 04.04.2015 um 23:58 schrieb Volker Fervers:
> Hello!
> in my parts?
> Thank you!
> GV
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
Re: [ECP] Model Explorer e4 [message #1691381 is a reply to message #1691379] Mon, 06 April 2015 16:07 Go to previous messageGo to next message
Hi Jonas!
I installed the Modelling Edition of Luna SR2 (4.4.2) and updated ECP to 1.5.1.
The ECP (or EMFForms, they are the same files, 151.zip) downloads contain the validation e4 components: (jar and source) whilst the target platform archive contains the e4, demo and sdk features and ui.e4, ui.validation.e4 w/ source, emfstore.ui.e4 w/ source and application e4 jars.
Thanks for your support!
GV
Re: [ECP] Model Explorer e4 [message #1691418 is a reply to message #1691381] Tue, 07 April 2015 03:34 Go to previous messageGo to next message
great that it works now!
Best regards
Jonas
Am 06.04.2015 um 22:07 schrieb Volker Fervers:
> Hi Jonas!
> 1.5.1.
> jars.
> GV
Re: [ECP] Model Explorer e4 [message #1691460 is a reply to message #1691418] Tue, 07 April 2015 08:35 Go to previous messageGo to next message
Hello!
Sadly it's still not working. I (re-)installed the available e4-features and plugins from the target platform zip. There is no "org.eclipse.emf.ecp.application.e4.product" for the run configuration, no "org.eclipse.emf.ecp.demo.e4.feature" and no source files for the demo application.
I know how to call the forms editor:
final ViewModelContext vmc = ViewModelContextFactory.INSTANCE.createViewModelContext(				ViewProviderHelper.getView(eObject, null), eObject, new DefaultReferenceService());
			try {
				ECPSWTViewRenderer.INSTANCE.render(content, vmc);
			} catch (final ECPRendererException ex) {
				Activator.log(ex);
But how do I call the Model Explorer to display my model's tree in a part?
Greetings
GV
Re: [ECP] Model Explorer e4 [message #1691580 is a reply to message #1691460] Wed, 08 April 2015 05:51 Go to previous messageGo to next message
OK, I just realized, since 1.5.1, the e4 support is on our target update
site only. Please go to the download page:
https://www.eclipse.org/ecp/download.html
And install the e4 SDK. This should add the missing bundles. Please let
me know, if this worked, we will update the documentation then.
Best regards
Jonas
Am 07.04.2015 um 14:35 schrieb Volker Fervers:
> Hello!
> demo application.
> try {
> Activator.log(ex);
> Greetings
> GV
Re: [ECP] Model Explorer e4 [message #1691593 is a reply to message #1691580] Wed, 08 April 2015 07:30 Go to previous messageGo to next message
Hello!
I installed the SDK e4 (it's in EMF Client Platform Features and not under All SDKs).
Now I see my fault: there are no source files for the e4 demo application in the feature "ECP E4 Demo Application incl. Sources". "Sources" relates to the included features "UI Integration" and "EMF Forms Runtime" but not to "E4 Demo Application".
GV
Re: [ECP] Model Explorer e4 [message #1821628 is a reply to message #1691593] Mon, 17 February 2020 14:21 Go to previous messageGo to next message
Can you please tell me how did you solve this problem?
Re: [ECP] Model Explorer e4 [message #1821664 is a reply to message #1821628] Tue, 18 February 2020 06:27 Go to previous message
I believe the solution is described above. Maybe you describe your current issue, so we can try to help you.
Jonas
Previous Topic:Generate actor system from an EMF meta-model
Next Topic:Template model editor issue
Current Time: Sun Jul 20 16:32:10 EDT 2025
Powered by FUDForum. Page generated in 0.05209 seconds
