Home » Modeling » ATL » Access to UML stereotypes from ATL EMFTVM script...
Access to UML stereotypes from ATL EMFTVM script... [message #1820924] Fri, 31 January 2020 19:38 Go to next message
Currently working on a SysML to OWL model transformation project, using Eclipse EMF 2019-12 and ATL 4.2.0.
I recently discovered that helpers ATL scripts can't access the SysML stereotypes embedded in sample input SysML models, when launched using EMFTVM ANT tasks. They do however, when run from an Eclipse EMFTVM launch configuration.
I could not spot the difference between my settings in build.xml and those from the exported launch config file.
Both files are listed below.
My question is: how should I correct the ANT script so the transformation rules (particularly their filters) and helpers can see the SysML UML stereotypes and process them the way they do when run from the launch config?
Thank you!
-- Olivier.
sysml2owl-emftvm.launch
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<launchConfiguration type="org.eclipse.m2m.atl.emftvm.launcher.EMFTVMTransformation">
<stringAttribute key="ATL File Name" value="//TestEMFTVM/transformations/SYSML2OWL.atl"/>
<booleanAttribute key="Disable JIT compiler" value="false"/>
<booleanAttribute key="Display Profiling Data" value="false"/>
<booleanAttribute key="Display Timing Data" value="true"/>
<mapAttribute key="Inout Model Options"/>
<mapAttribute key="Inout Models"/>
<mapAttribute key="Inout Models Output Locations"/>
<mapAttribute key="Input Model Options"/>
<mapAttribute key="Input Models">
<mapEntry key="IN" value="platform:/resource/TestEMFTVM/models/SampleModel.uml"/>
</mapAttribute>
<mapAttribute key="Metamodel Options"/>
<mapAttribute key="Metamodels">
<mapEntry key="OWL" value="platform:/resource/TestEMFTVM/metamodels/OWL/OWL.ecore"/>
<mapEntry key="UML" value="http://www.eclipse.org/uml2/5.0.0/UML"/>
</mapAttribute>
<stringAttribute key="Module Name" value="SYSML2OWL"/>
<stringAttribute key="Module Path" value="/TestEMFTVM/transformations/"/>
<mapAttribute key="Output Model Options">
<mapEntry key="OUT" value="allowIntermodelReferences derivedFile"/>
</mapAttribute>
<mapAttribute key="Output Models">
<mapEntry key="OUT" value="platform:/resource/TestEMFTVM/models/SampleModel.owl"/>
</mapAttribute>
<listAttribute key="Superimpose">
<listEntry value="//TestEMFTVM/transformations/SYSMLLIB.asm"/>
</listAttribute>
</launchConfiguration>
build.xml
<!-- See examples at: https://github.com/dwagelaar/emftvm.maven.example/blob/master/build.xml
https://github.com/eclipse/atl/blob/master/plugins/org.eclipse.m2m.atl.emftvm.compiler/compiler-compiler/build.xml
<project name="SysML2OWL" default="all">
	<property name="project.basedir" value="${basedir}" />
	<property name="project.metamodels" value="${project.basedir}/metamodels" />
	<property name="project.models" value="${project.basedir}/models" />
	<property name="project.transformations" value="${project.basedir}/transformations" />
	<property name="project.local.dependencies" value="${project.basedir}/repository/dependencies" />
	<property name="project.build.directory" value="${project.basedir}/target" />
	<property name="project.build.library" location="${project.build.directory}/lib" />
	<property name="project.build.models" value="${project.build.directory}/models" />
	<property name="project.build.transformations" value="${project.build.directory}/transformations" />
	<property name="project.build.logs" value="${project.build.directory}/logs" />
	<!-- Change this value if you want to use another input model -->
	<property name="modelName" value="SampleModel"/>
	<property name="inModel" value="${modelName}.uml"/>
	<property name="odmEcoreOutput" value="${modelName}-ODM.ecore"/>
	<property name="odmXmiOutput" value="${modelName}-ODM.xmi"/>
	<target name="clean">
		<delete dir="${project.build.library}" includes="*.jar" excludes='antlr-runtime-*.jar'></delete>
		<delete dir="${project.build.transformations}" includes="*.emftvm"></delete>
		<delete dir="${project.build.models}" includes="*.jar"></delete>
	</target>
	<target name="all" depends="loadMetamodels,compileATL,transform" />
	<target name="loadMetamodels" depends="getLibrary">
		<emftvm.registerMetamodel packageClass="org.eclipse.emf.ecore.EcorePackage"
			resourceFactoryClass="org.eclipse.emf.ecore.xmi.impl.EcoreResourceFactoryImpl" fileExtension="ecore" />
		<emftvm.registerMetamodel packageClass="org.eclipse.uml2.uml.UMLPackage"
			resourceFactoryClass="org.eclipse.uml2.uml.internal.resource.UMLResourceFactoryImpl" fileExtension="uml" />
			resourceFactoryClass="org.eclipse.emf.ecore.xmi.impl.XMIResourceFactoryImpl" fileExtension="xmi" />
			resourceFactoryClass="org.eclipse.emf.ecore.xmi.impl.XMLResourceFactoryImpl" fileExtension="xml" />
		<emftvm.loadMetamodel name="UML" uri="http://www.eclipse.org/uml2/5.0.0/UML" />
		<emftvm.loadMetamodel name="OWL" uri="file:/${project.metamodels}/OWL/OWL.ecore" />
		<emftvm.loadMetamodel name="XML" uri="file:/${project.metamodels}/XML/XML.ecore"/>
	</target>
	<target name="compileATL" depends="loadMetamodels">
		<emftvm.compile module="SYSML2OWL"
			modulepath="${project.transformations}/" outputpath="${project.build.transformations}/" charset="UTF-8" />
		<emftvm.compile module="SYSMLLIB"
		<emftvm.compile module="OWL2XML"
	</target>
	<target name="transform" depends="compileATL">
		<echo message="Loading model ${inModel}" />
		<emftvm.loadModel name="${modelName}" uri="file:/${project.models}/${inModel}" />
		<echo message="Running file:/${project.build.transformations}/SYSML2OWL.emftvm" />
		<emftvm.run modulepath="file:/${project.build.transformations}/" module="SYSML2OWL">
			<metamodel name="UML" />
			<metamodel name="OWL" />
			<inputmodel name="${modelName}" as="IN" />
			<outputmodel name="${modelName}-ODM-ECORE" uri="file:/${project.build.models}/${odmEcoreModel}" as="OUT"  allowInterModelReferences="true" />
			<outputmodel name="${modelName}-ODM-match" as="match" uri="file:/${project.build.logs}/${modelName}-ODM-match.trace"/>
			<inoutmodel name="${modelName}-ODM-trace" as="trace" uri="file:/${project.build.logs}/${modelName}-ODM.trace"/>
		</emftvm.run>
		<echo message="Saving OWL model as Ecore" />
		<emftvm.saveModel name="${modelName}-ODM-match" uri="file:/${project.build.logs}/${modelName}-ODM-match.trace" />
		<emftvm.saveModel name="${modelName}-ODM-trace" uri="file:/${project.build.logs}/${modelName}-ODM.trace" />
		<emftvm.saveModel name="${modelName}-ODM-ECORE" uri="file:/${project.build.models}/${odmEcoreOutput}" />
		<emftvm.saveModel name="${modelName}-ODM-ECORE" uri="file:/${project.build.models}/${odmXmiOutput}" />
	</target>
	<target name="getLibrary" depends="init">
		<get src="https://repo.maven.apache.org/maven2/org/eclipse/equinox/org.eclipse.equinox.common/3.6.0.v20100503/org.eclipse.equinox.common-3.6.0.v20100503.jar"
				dest="${project.build.library}" skipexisting="true" />
		<get src="https://repo.maven.apache.org/maven2/org/eclipse/emf/org.eclipse.emf.ecore/2.12.0/org.eclipse.emf.ecore-2.12.0.jar"
		<get src="https://repo.maven.apache.org/maven2/org/eclipse/emf/org.eclipse.emf.common/2.12.0/org.eclipse.emf.common-2.12.0.jar"
		<get src="https://repo.maven.apache.org/maven2/org/eclipse/emf/org.eclipse.emf.ecore.xmi/2.12.0/org.eclipse.emf.ecore.xmi-2.12.0.jar"
		<get src="https://repo.maven.apache.org/maven2/org/eclipse/emf/org.eclipse.emf.mapping.ecore2xml/2.9.0-v20150806-0404/org.eclipse.emf.mapping.ecore2xml-2.9.0-v20150806-0404.jar"
		<get src="https://repo.maven.apache.org/maven2/org/ow2/asm/asm/6.0_BETA/asm-6.0_BETA.jar"
		<get src="https://repo.maven.apache.org/maven2/org/antlr/antlr-runtime/3.0.1/antlr-runtime-3.0.1.jar"
		<get src="https://repo.maven.apache.org/maven2/org/eclipse/core/runtime/3.10.0-v20140318-2214/runtime-3.10.0-v20140318-2214.jar"
		<get src="https://repo.maven.apache.org/maven2/org/eclipse/uml2/uml/5.0.0-v20140602-0749/uml-5.0.0-v20140602-0749.jar"
		<get src="https://repo.maven.apache.org/maven2/org/eclipse/uml2/common/2.0.0-v20140602-0749/common-2.0.0-v20140602-0749.jar"
		<get src="https://repo.maven.apache.org/maven2/org/eclipse/uml2/types/2.0.0-v20140602-0749/types-2.0.0-v20140602-0749.jar"
		<get src="https://repo.maven.apache.org/maven2/org/eclipse/uml2/uml/profile/standard/1.0.0-v20140602-0749/standard-1.0.0-v20140602-0749.jar"
		<get src="https://repo.eclipse.org/content/groups/atl/org/eclipse/m2m/atl/org.eclipse.m2m.atl.emftvm.ant.standalone/4.1.0/org.eclipse.m2m.atl.emftvm.ant.standalone-4.1.0.jar"
		<taskdef resource="org/eclipse/m2m/atl/emftvm/ant/antlib.xml">
			<classpath>
				<fileset dir="${project.build.library}" includes="**/*.jar" />
			</classpath>
		</taskdef>
	</target>
	<target name="init">
		<mkdir dir="${project.build.library}" />
		<mkdir dir="${project.build.models}" />
		<mkdir dir="${project.build.logs}" />
		<mkdir dir="${project.build.transformations}" />
	</target>
</project>
[Updated on: Fri, 31 January 2020 19:41] by Moderator
Re: Access to UML stereotypes from ATL EMFTVM script... [message #1823657 is a reply to message #1820924] Mon, 30 March 2020 15:35 Go to previous messageGo to next message
Still stuck on this... Any idea?
-- OHM.
Re: Access to UML stereotypes from ATL EMFTVM script... [message #1830719 is a reply to message #1823657] Sat, 01 August 2020 09:08 Go to previous messageGo to next message
I'm suspecting that you run your ant script in its own JVM (i.e. standalone). If that's the case, it probably won't have all the environment variables of the Eclipse environment available, some of which point to standard UML profiles (e.g. "pathmap://UML_PROFILES/Standard.profile.uml"). Can you share an example UML model that exhibits your problem, such that we can what other models it references?
Re: Access to UML stereotypes from ATL EMFTVM script... [message #1831254 is a reply to message #1820924] Sat, 15 August 2020 10:58 Go to previous message
Currently working on a sysml(requirement diagrame) to owl model transformation project, using Eclipse
I made a requirement diagrame exemple but i dont now How do I transfer it to owl cane tou help me??? please
Previous Topic:How to certain rules with entered paramter to an Attribute?
Next Topic:Select the features to be transformed using if else statements in rules
Current Time: Sun Jul 20 18:32:24 EDT 2025
Powered by FUDForum. Page generated in 0.04304 seconds
