Home » Modeling » TMF (Xtext) » Facing problem in cross references
Facing problem in cross references [message #1819208] Fri, 10 January 2020 00:03 Go to next message
I have one existing model named as mydsl, and i am importing to my grammar like this-
grammar org.xtext.example.mydsl1 with org.eclipse.xtext.common.Terminals
import "http://www.xtext.org/example/mydsl " as mydsl
generate mydsl1 "http://www.xtext.org/example/mydsl1"
I have added referencedResource in mwe2 workflow.
In my grammar i am referring mydsl like -
('Package:' packages+=[mydsl::EPackage|STRING] (packages+=[mydsl::EPackage|STRING])*)?
Here my problem is in Xtext editor if add instances of epackage i am getting error " Couldn't resolve reference to epackage "
So if anyone has any suggestions, what I should check or fix or use, please let me know.
Re: Facing problem in cross references [message #1819213 is a reply to message #1819208] Fri, 10 January 2020 01:36 Go to previous messageGo to next message
does the project with the metamodel have Xtext nature and is added to the dependencies of the mydsl project?
Re: Facing problem in cross references [message #1819227 is a reply to message #1819213] Fri, 10 January 2020 04:09 Go to previous messageGo to next message
Yes, the project with the metamodel have Xtext nature. In dependency also i have added.
Re: Facing problem in cross references [message #1819231 is a reply to message #1819227] Fri, 10 January 2020 04:41 Go to previous messageGo to next message
could you provide a small reproducing example?
Re: Facing problem in cross references [message #1819553 is a reply to message #1819231] Fri, 17 January 2020 04:15 Go to previous messageGo to next message
This is my mydsl grammar-
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
generate myDsl "http://www.xtext.org/example/mydsl/MyDsl"
Model:
packages+=EPackage*;
EPackage:
{EPackage}
'EPackage{'
('PackageName:' packageName=String0)?
String0 returns ecore::EString:
ID* & INT* & '-'*
And mydsl1 grammar-
grammar org.xtext.example.mydsl1.MyDsl1 with org.eclipse.xtext.common.Terminals
import "http://www.xtext.org/example/mydsl/MyDsl" as myDsl
generate myDsl1 "http://www.xtext.org/example/mydsl1/MyDsl1"
ModelClass:
classes+=Class*;
Class:
{Class}
'Class{'
('ClassName:' className=String0)?
('Package:' packages+=[myDsl::EPackage|String0])?
ID* & INT* & '-'*
Work flow -
Workflow {
component = XtextGenerator {
configuration = {
project = StandardProjectConfig {
baseName = "org.xtext.example.mydsl1"
rootPath = rootPath
runtimeTest = {
enabled = true
eclipsePlugin = {
enabled = true
eclipsePluginTest = {
enabled = true
createEclipseMetaData = true
code = {
encoding = "windows-1252"
lineDelimiter = "\r\n"
fileHeader = "/*\n * generated by Xtext \${version}\n */"
language = StandardLanguage {
name = "org.xtext.example.mydsl1.MyDsl1"
fileExtensions = "mydsl1"
referencedResource = "platform:/resource/org.xtext.example.mydsl/model/generated/MyDsl.genmodel"
serializer = {
generateStub = false
parserGenerator = {
antlrParam = "-Xmaxinlinedfastates" antlrParam = "100000"
antlrParam = "-Xmaxswitchcaselabels" antlrParam = "30000"
antlrParam = "-Xminswitchalts" antlrParam="1"
options = {
backtrack = true
classSplitting = true
fieldsPerClass = "2000"
methodsPerClass = "2000"
validator = {
// composedCheck = "org.eclipse.xtext.validation.NamesAreUniqueValidator"
// Generates checks for @Deprecated grammar annotations, an IssueProvider and a corresponding PropertyPage
generateDeprecationValidation = true
junitSupport = {
junitVersion = "5"
So if i am trying to refer the package in mydsl1 from mydsl, i am getting "Couldn't resolve reference to EPackage"
I have attached the Runtime xtext editor image.
Re: Facing problem in cross references [message #1819558 is a reply to message #1819553] Fri, 17 January 2020 05:23 Go to previous messageGo to next message
EPackage:
{EPackage}
'EPackage{'
how does your qualified name provider look like
Re: Facing problem in cross references [message #1819567 is a reply to message #1819558] Fri, 17 January 2020 06:59 Go to previous messageGo to next message
I have not implemented any qualified name provider.
Re: Facing problem in cross references [message #1819570 is a reply to message #1819567] Fri, 17 January 2020 07:24 Go to previous message
xtext ill give only things a name that have an attribute name. yours does not. see https://www.dietrich-it.de/xtext/2011/07/16/iqualifiednameproviders-in-xtext-2-0.html
Previous Topic:Custom coloring for block of code
Next Topic:Orion Web Editor: xtext-web functions are not available
Current Time: Sun Jul 20 15:22:09 EDT 2025
Powered by FUDForum. Page generated in 0.04704 seconds
