Java11 e4 application openjfx [message #1819395] |
Tue, 14 January 2020 09:39  |
Hello everybody,
I am having some trouble getting an e4 application, together with openjfx and java11 (AdoptOpenJDK) to run.
The content of my target file looks like this:
<locations>
<location includeAllPlatforms="false" includeConfigurePhase="true" includeMode="planner" includeSource="true" type="InstallableUnit">
<repository location="http://download.eclipse.org/efxclipse/runtime-released/3.5.0/site/"/>
<unit id="org.eclipse.fx.core.feature.feature.group" version="3.5.0.201902252257"/>
<unit id="org.eclipse.fx.slf4j.target.feature.feature.group" version="3.5.0.201902250700"/>
<unit id="org.eclipse.fx.target.feature.feature.group" version="3.5.0.201902252257"/>
</location>
<repository location="http://download.eclipse.org/eclipse/updates/4.9"/>
<unit id="org.eclipse.platform.sdk" version="4.9.0.I20180906-0745"/>
</location>
<repository location="http://downloads.efxclipse.bestsolution.at/p2-repos/openjfx-11/repository/"/>
<unit id="openjfx.media.feature.feature.group" version="11.0.0.201901231300"/>
<unit id="openjfx.standard.feature.feature.group" version="11.0.0.201901231300"/>
<unit id="openjfx.swing.feature.feature.group" version="11.0.0.201901231300"/>
<unit id="openjfx.swt.feature.feature.group" version="11.0.0.201901231300"/>
<unit id="openjfx.web.feature.feature.group" version="11.0.0.201901231300"/>
</location>
</locations>
but unless I add " --module-path <local-path>\javafx-sdk-11.0.2\lib --add-modules javafx.graphics,javafx.controls,javafx.fxml", I always get the following error when running (note: the projects compiles fine with this target):
!SESSION 2020-01-14 15:26:49.990 -----------------------------------------------
eclipse.buildId=unknown
java.version=11.0.5
java.vendor=AdoptOpenJDK
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=de_DE
Framework arguments: -product <shortened>.application.product
Command-line arguments: -product <shortened>.application.product -data <shortened>.app.product.product -dev file:<shortened>/.metadata/.plugins/org.eclipse.pde.core/<shortened>.app.product.product/dev.properties -os win32 -ws win32 -arch x86_64 -consoleLog -data @user.home/ws
!ENTRY org.eclipse.equinox.app 4 0 2020-01-14 15:26:52.996
!MESSAGE javafx/application/Application
!STACK 0
java.lang.NoClassDefFoundError: javafx/application/Application
at java.base/java.lang.ClassLoader.defineClass1(Native Method)
at java.base/java.lang.ClassLoader.defineClass(ClassLoader.java:1016)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.defineClass(ModuleClassLoader.java:279)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.defineClass(ClasspathManager.java:703)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findClassImpl(ClasspathManager.java:626)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClassImpl(ClasspathManager.java:594)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClassImpl(ClasspathManager.java:574)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:553)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:331)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:395)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:473)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:422)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:414)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:153)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:521)
at org.eclipse.fx.ui.workbench.fx.E4Application.getJfxApplicationClass(E4Application.java:396)
at org.eclipse.fx.ui.workbench.fx.E4Application.launchE4JavaFxApplication(E4Application.java:381)
at org.eclipse.fx.ui.workbench.fx.E4Application.start(E4Application.java:179)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:199)
at org.eclipse.equinox.internal.app.AnyThreadAppLauncher.run(AnyThreadAppLauncher.java:29)
at java.base/java.lang.Thread.run(Thread.java:834)
Caused by: java.lang.ClassNotFoundException: javafx.application.Application cannot be found by org.eclipse.fx.ui.workbench.fx_3.5.0.201902252257
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:511)
... 21 more
Does anyone know what is missing in order to get this to run?
Best regards.
[Updated on: Fri, 17 January 2020 07:02] by Moderator
Re: Java11 e4 application openjfx [message #1819568 is a reply to message #1819526] |
Fri, 17 January 2020 07:01  |
I think I might have got it!
Looking at your first reply, I checked the feature.xml again and now added the openjfx features as "Included Features" and that seems to have done the trick (I feel like I've tried that before, but maybe something else went wrong back then).
Thanks!!!
FUDForum. Page generated in 0.04285 seconds
