Problem starting Jetty version 9.4.24.v20191120 [message #1819366] |
Mon, 13 January 2020 21:18  |
Hi ,
I am upgrading jetty from version 9.1.6.v20160112 to 9.4.24.v20191120 , when I am starting jetty I am getting below exception , could you suggest what could be the solution for this
Starting Jetty: java.lang.reflect.InvocationTargetException
at org.eclipse.jetty.start.Main.invokeMain(Main.java:218)
at org.eclipse.jetty.start.Main.start(Main.java:491)
at org.eclipse.jetty.start.Main.main(Main.java:77)
Caused by: java.lang.NoSuchMethodError: org.eclipse.jetty.util.StringUtil.valueOf(Ljava/lang/Object;)Ljava/lang/String;
at org.eclipse.jetty.xml.XmlConfiguration$JettyXmlConfiguration$AttrOrElementNode.getString(XmlConfiguration.java:1379)
at org.eclipse.jetty.xml.XmlConfiguration$JettyXmlConfiguration.newObj(XmlConfiguration.java:827)
at org.eclipse.jetty.xml.XmlConfiguration$JettyXmlConfiguration.configure(XmlConfiguration.java:478)
at org.eclipse.jetty.xml.XmlConfiguration$JettyXmlConfiguration.configure(XmlConfiguration.java:413)
at org.eclipse.jetty.xml.XmlConfiguration.configure(XmlConfiguration.java:311)
at org.eclipse.jetty.xml.XmlConfiguration$1.run(XmlConfiguration.java:1558)
at org.eclipse.jetty.xml.XmlConfiguration$1.run(XmlConfiguration.java:1512)
at org.eclipse.jetty.xml.XmlConfiguration.main(XmlConfiguration.java:1511)
... 7 more
... 7 more
Usage: java -jar $JETTY_HOME/start.jar [options] [properties] [configs]
java -jar $JETTY_HOME/start.jar --help # for more information
FAILED Tue Jan 14 04:15:17 EET 2020
I also checked the classfile of org.eclipse.jetty.xml.XMLConfiguration , it seems deprecated .
Re: Problem starting Jetty version 9.4.24.v20191120 [message #1819419 is a reply to message #1819414] |
Tue, 14 January 2020 17:25  |
Issue is resolved now , It was actually taking jetty jars from two of the classpath one is open jdk and the other is jetty classpath , hence at runtime it was confused which version of jetty util , jetty xml to be picked and was resulting in InvocationTargetException. Somehow older version of jetty util and jetty xmls were available in my jdk lib folder . Removing those fixed the errors.
FUDForum. Page generated in 0.08419 seconds
