Error recovery ? [message #1818893] |
Tue, 31 December 2019 19:15  |
Workspace mix-up and how to recover from it ?
I am not sure what caused this , but that is immaterial.
I am asking the group assistance HOW to recover from this error.
I can access the log file, but it is HUGE , not really showing current date (?) AND most of all does not offer a solution.
I suspect something to do with "busy" workspace - which is "common" error I get and it is easy to recover from by switching / changing / selecting another workspace. NOT AN ISSUE.
But the "log" error give me NO OPTION but to quit Eclipse.
There ARE NO OTHER OPTIONS PRESENTED to restore current Eclipse run - except to run ANOTHER working copy of Eclipse .
HOW do I restore THIS , error giving , Eclipse (version) to normal operation ?
Re: Error recovery - clean log added 1/12/2020 [message #1818907 is a reply to message #1818899] |
Wed, 01 January 2020 09:56   |
Here is today's .log attempt to run Eclipse.
It is still pretty big.
Addendum
NEW CLEAN LOG FILE ATTACHED
Sorry, I forgot how to add / attach file in "reply".
Ed, here is a clean, today, copy of the error log.
Unless it is easy to find out what went wrong, do not spent much time analysing it.
In essence - upgrading form Eclipse 2019--x is a gamble.
The safest way is to do clean download , add necessary plug-ins (pain), create clean new workspace and then import the projects from the old workspace.
The very old and annoying issue - cannot work on workspace created by "OLD" IDE gets in the way big time.
Attachment: .log
(Size: 301.02KB, Downloaded 153 times)
Attachment: Eclipse.log.odt
(Size: 21.91KB, Downloaded 151 times)
[Updated on: Sun, 12 January 2020 11:39] by Moderator
Re: Error recovery ? [message #1819317 is a reply to message #1818960] |
Mon, 13 January 2020 01:11  |
There are still many "Sessions" in this .log. The newest is !SESSION 2020-01-01 08:43:49.188 and that's the one where it's having trouble restoring the tree. That workspace is probably hosed, for whatever reason, so it is no doubt best to create/use a new workspace. I don't generally expect that an update of the IDE will hose the old workspace though, but once you use a workspace with a newer IDE, it might no longer function with an older one.
FUDForum. Page generated in 0.12267 seconds
