Home » General (non-technical) » Eclipse Foundation » Tomcat Error(Eclipse complains about wrong http port)
Tomcat Error [message #1819001] Sat, 04 January 2020 08:44 Go to next message
Hi there,
I have Tomcat 9 running on localhost:8080. It shows the tomcat default page on the browser, which means it's up and running.
I also have the tomcat port configured as 8080 in the eclipse properties
(See attached screenshots)
When I run the application, i get the following error:
"The server cannot be started because one or more of the ports are invalid. Open the server editor and correct the invalid ports."
Any clues on how to fix this?
thanks in advance
Bruno
Re: Tomcat Error [message #1819187 is a reply to message #1819001] Thu, 09 January 2020 11:22 Go to previous messageGo to next message
You should probably ask this to another forum, like https://www.eclipse.org/forums/index.php/f/251/ or https://www.eclipse.org/forums/index.php/f/88/
Re: Tomcat Error [message #1826047 is a reply to message #1819001] Fri, 17 April 2020 11:35 Go to previous messageGo to next message
Running Tomcat or a web-app from Eclipse is done by launching a new instance of Tomcat, configured the way you've set it up in the Servers view. The message you're seeing is correct, as both your installed and launched instance can not both listen on the same port at the same time. You'll have to change one of them.
[Updated on: Fri, 17 April 2020 11:35] by Moderator
Re: Tomcat Error [message #1833169 is a reply to message #1826047] Mon, 05 October 2020 07:08 Go to previous message
See this
https://stackoverflow.com/questions/59471438/cant-start-tomcatv9-0-in-eclipse
Previous Topic:Eclipse IDE for Java EE Developers ISSUE
Next Topic:a beginner to use Eclipse - building project issue
Current Time: Sun Jul 20 04:41:56 EDT 2025
Powered by FUDForum. Page generated in 0.04147 seconds
