Home » Newcomers » Newcomers » Java 12 Advanced LookUp Disabled(Please help me understand and fix this issue)
Java 12 Advanced LookUp Disabled [message #1819031] Sun, 05 January 2020 11:33 Go to next message
Good morning,
I'm a newcomer to Eclipse and to programming overall . I come across this message when I hit the debug button. "JRE Oracle Corporation/12.0.1 is not supported, advanced source lookup disabled."
Could you please explain what advanced source lookup is and what its purpose is? What does this message means? Is it indicating I'm having a problem? Does having "advanced source lookup disabled" impact my ability to fully test and debug and program effectively? Other than this message, I'm not noticing any other bugs or potential errors. Any advice and assistance would be greatly appreciated.
I have Eclipse version Version: 2019-06 (4.12.0)
Build id: 20190614-1200
Checked for updates. This appears to be the latest of Eclipse that I'm aware of.
Thank you, I really appreciate it,
Michelle
Re: Java 12 Advanced LookUp Disabled [message #1819038 is a reply to message #1819031] Mon, 06 January 2020 01:25 Go to previous message
If you installed the 2019-12 version or updated to this version from the http://download.eclipse.org/releases/2019-12 site, it has support for Java 12. More details about this message are mentioned here:
https://www.eclipse.org/forums/index.php/mv/msg/1101423/1817701/#msg_1817701
Previous Topic:can't install eclipse if mse(antivirus) is on
Next Topic:Paho Java client is NOT receiving MQTT events.
Current Time: Sat Jul 19 20:56:40 EDT 2025
Powered by FUDForum. Page generated in 0.07355 seconds
