Can't debug startup code Reset_Handler [message #1819016] |
Sat, 04 January 2020 15:01 |
Hi, maybe somebody can help me with this. I am trying to debug the startup code for my kl25z freedom board. I set a breakpoint at Reset_Handler label which is in file startup_MKL25Z4.S
I am using GDB PEMicro Interface Debugging plugin. In the eclipse 2019-12 Debug Configurations Startup tab, I set breakpoint at Reset_Handler (the label in startup code at address 0x4d0) and uncheck Run on reset checkbox. When starting debugging a new tab is created in the editor with a message:
"Break at address 0x4d0 with no debug information available, or outside of program code"
The code is compiled with debugging information with the -ggdb flag and optimization set to -O0 (no optimatization).
If I set the breakpoint at main, the program debug just fine, I can step through it.
Thanks in advance,
Anthony H.
FUDForum. Page generated in 1.08451 seconds
