Home » Newcomers » Newcomers » Mosquitto(Multiple publications to the same topic)
Mosquitto [message #1818925] Thu, 02 January 2020 17:15 Go to next message
We are NEW to MQTT. Our devices are publishing to the same topic. All is good when publishing from one device. However, whenever we attempt to publish from 2+ devices at the same time, only one devices is successfully able to open a connection to the broker. We're missing something obvious. Thank you in advance.
Re: Mosquitto [message #1818926 is a reply to message #1818925] Thu, 02 January 2020 17:23 Go to previous message
mosquitto.org suggests discussing with other users using the mailing list: https://dev.eclipse.org/mailman/listinfo/mosquitto-dev
Previous Topic:Eclipse Reports (BIRT) Chart FAILED_TO_CREATE_INSTANCE
Next Topic:I plan to learn to write plugin for Eclipse, where should I start at
Current Time: Sun Jul 20 17:56:40 EDT 2025
Powered by FUDForum. Page generated in 0.07846 seconds
