Home » Modeling » EMF » Fail to get inherited EAttribute with Resource.getObject(String uriFragment)
Fail to get inherited EAttribute with Resource.getObject(String uriFragment) [message #1818757] Fri, 27 December 2019 05:56 Go to next message
Hi everyone,
I encounter the following problem, both with old org.eclipse.emf.ecore old 2.12 or more recent 2.19.
I create a EPackage dynamically and register it in EPackage.Registry (i.e. no genmodel). There is a EClass "A" defining a EAttribute "name", and a EClass "B" inheriting from "A".
  • Test1 : When I first try to get the "name" EAttribute with Resource#getObject("/0/B/name") (invoked on resource containing dynamic EPackage instance) -> I obtain null.
  • Test2: after a sequence of various other invocations, including EClass#getEStructuralFeature(...) on B, a new try on Resource#getObject("/0/B/name") will success in giving the "name" EAttribute.
Debugging into the Resource#getObject(..) brings me to EClassImpl#eObjectForURIFragmentSegment(String uriFragmentSegment) code. If "eAllStructuralFeaturesData" cache has been initialized before ("Test2" case), we get the result from getEStructuralFeature(..). Else ("Test1" case) the code delegates to super.eObjectForURIFragmentSegment(..) which searches on direct contained features (from B) but not on super types (like A).
Is it a wrong idea to try to get "name" from uri "/0/B/name" rather than "/0/A/name" ?
For now i have a simple workaround in adding a loop of "useless" EClass#getEAllStructuralFeatures() invocations, just after dynamic EPackage creation.
Thanks for help.
Re: Fail to get inherited EAttribute with Resource.getObject(String uriFragment) [message #1818759 is a reply to message #1818757] Fri, 27 December 2019 07:45 Go to previous messageGo to next message
Technically it's not 100% correct that the optimization in eObjectForURIFragmentSegment that calls getEStructuralFeature ever returns a feature that isn't contained by the EClass instance. But no serializer would ever produce that fragment path in the first place., because a reference to the feature "name" would build a fragment path that navigates though "A" not through "B". But the context of your question is missing, i.e., where does a path like "/0/B/name" come from in the first place? That isn't a good idea and you should not try to get it to work with workarounds but rather should avoid this.
Re: Fail to get inherited EAttribute with Resource.getObject(String uriFragment) [message #1818761 is a reply to message #1818759] Fri, 27 December 2019 09:37 Go to previous message
Thanks for the explanation,
"/0/B/name" kind of path is produced by one of our tool which iterates on all attributes for some EClasses. It produces automatically some EMFFacet model where one FacetAttribute references indirectly one EAttribute by this "/0/B/name" path.
The mechanism has worked for a long time. The bad practice is now revealed since we have changed from java generated to dynamic EPackage.
I will see in our tool implementation to fix it.
Previous Topic:Behaviors for proxy contained in containment feature after
Next Topic:Ecore Inheritance in the same Namespace
Current Time: Sat Jul 19 14:39:38 EDT 2025
Powered by FUDForum. Page generated in 0.05018 seconds
