Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » Subscrible on raspberry
Subscrible on raspberry [message #1818716] Tue, 24 December 2019 08:27 Go to next message
when i run forte with a simple FB subscribe
it throw an error:
INFO: T#1366997896321863: CBSDSocketInterface: Opening UDP receiving connection at: 192.168.10.171:61500
INFO: T#1366997896321863: Connection closed by peer
WARNING: T#2465796559782561: CBSDSocketInterface: setsockopt(IP_ADD_MEMBERSHIP) failed: Invalid argument
ERROR: T#2465796559782561: CModbusComLayer:: Invalid input parameters
INFO: T#2465796559782561: CModbusLayer::closeConnection()
DEBUG: T#7154079781972633: CSocketBaseLayer::closeConnection()
Re: Subscrible on raspberry [message #1818717 is a reply to message #1818716] Tue, 24 December 2019 08:36 Go to previous messageGo to next message
sorry, i see the error came from modbus, i will check the parameters if were correct.
Re: Subscrible on raspberry [message #1818718 is a reply to message #1818717] Tue, 24 December 2019 08:38 Go to previous messageGo to next message
beacuse i don't have the new modbus documentation & ftbs, i can only use the old modbus
Re: Subscrible on raspberry [message #1818739 is a reply to message #1818718] Thu, 26 December 2019 05:12 Go to previous message
The modbus situation for 4diac is currently rather bad. We don't have any modbus devices for testing and also not the need. Anybody who want to step in to improve the situation is warmly welcome. However the starting point should be the patches from Martin Jobst.
Previous Topic:Raspberry forte 's debugging problem
Next Topic:HMI question
Current Time: Sat Jul 19 11:43:04 EDT 2025
Powered by FUDForum. Page generated in 0.05540 seconds
