Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » Integrating LUA with Docker(Error at Cross Compiling Forte with LUA in Docker for Lego Mindstorms)
Integrating LUA with Docker [message #1818295] Wed, 11 December 2019 11:28 Go to next message
Before integrating LUA into Docker, I already sucessfully integrated OPC UA for Lego Mindstorms. Now I want to use the LUA compiler for the EV3 Brick. For that I added the luajit-2.0 library to my folder hirarchy by using
git clone ...... luajit-2.0.git
in the Docker container. I also did "make" where I got the "libluajit.so"-file.
Then I added the following commands into my configuration file for compiling forte:
-DFORTE_USE_LUATYPES=LUAJIT
-DLUAJIT_INCLUDE_DIR=/4diac/luajit-2.0/src
-DLUAJIT_LIBRARY=/4diac/luajit-2.0/src/libluajit.so
Where "4diac" is the root folder of my docker container.
After all, when trying to compile forte, I get the error as shown in the screen shot in the attachments. This is where I don't know how to solve this problem.
I also added the ocnfiguration file and a screenshot of the folder hirarchy I use for compiling forte.
Thank you in advance
Re: Integrating LUA with Docker [message #1818335 is a reply to message #1818295] Thu, 12 December 2019 11:52 Go to previous messageGo to next message
Hi Robert!
Are you trying to compile the forte on Windows or Linux?
Alois also suggest we could meet if you want. I already wrote you an email.
Jan
Re: Integrating LUA with Docker [message #1818406 is a reply to message #1818335] Sat, 14 December 2019 11:27 Go to previous messageGo to next message
when you are meeting in person, can you please document the outcome in this post for others.
thx,
Alois
Re: Integrating LUA with Docker [message #1818603 is a reply to message #1818295] Fri, 20 December 2019 07:05 Go to previous message
The solution for this problem was to configure the correct path in the commands that I added in the configuration file for compiling forte:
-DluaJIT_INCLUDE_DIR=/4diac/luajit-2.0/
Now it compiles without any errors
Previous Topic:Error when using the INIT event
Next Topic:custom UDP messages
Current Time: Sun Jul 20 13:26:33 EDT 2025
Powered by FUDForum. Page generated in 0.05897 seconds
