Eclipse does not build C++ files [message #1818106] |
Fri, 06 December 2019 01:24  |
I am trying to compile on Eclipse a project with C and C++ files (.c and .cpp)
I have an error code indicating at linking step that one of my function is not referenced (undefined reference to 'main_application'), and after some investigation I could spot that although I can find it in the project code, all files in .cpp are not compiled, therefore it cannot find their reference.
What I cannot understand is why the g++ compiler is not used for cpp files, while I have it: when I go to my projec properties >> C/C++ build >> ToolCahin Editor, I have as a current toolchain a "GCC 5.3.0 [x86_64-w64-mingw32]", current builder = GNU Make builder, and in the used tools
GCC C++ Compiler 5.3.0 [x86_64-w64-mingw32]
GCC C Compiler 5.3.0 [x86_64-w64-mingw32]
GCC Assembler 5.3.0 [x86_64-w64-mingw32]
GCC C++ Linker 5.3.0 [x86_64-w64-mingw32]
GCC C Linker 5.3.0 [x86_64-w64-mingw32]
GCC Archiver 5.3.0 [x86_64-w64-mingw32]
so I have the C++ compilers, how can I activate them on my c++ files ?
When I build, in the "build" folder (build is my configuration name) I only have the objects (.o) files for .c files, not .cpp files which are never compiled.
FUDForum. Page generated in 0.04134 seconds
