Home » Eclipse Projects » Rich Client Platform (RCP) » Setting the correct build configuration
Setting the correct build configuration [message #1818220] Tue, 10 December 2019 07:02 Go to next message
I am creating an Eclipse plugin and came in contact with the following problem... I have a C project, a number of build configs and the same number of launch configurations(for each launch configuration there is a specific build configuration that needs to be done before running).
At the moment, when I run the project, it first builds with the active build configuration and then launches.
Is there a way of setting the correct build configuration for the specific run configuration?
Thank you!
Re: Setting the correct build configuration [message #1818238 is a reply to message #1818220] Tue, 10 December 2019 14:28 Go to previous message
I guess that you can better ask this at the Eclipse CDT forum: https://www.eclipse.org/forums/index.php?t=thread&frm_id=80
Previous Topic:Integrating QT with Eclipse
Next Topic:Get the current launch configuration
Current Time: Sun Jul 20 08:51:37 EDT 2025
Powered by FUDForum. Page generated in 0.03454 seconds
