Help non-Linux/non-Java embedded C developer make use of Trace Compass [message #1794462] |
Thu, 30 August 2018 17:27  |
Hi all
I'm developing C on bare metal ARM Cortex (M3) with a very basic custom OS (no Linux) and am attempting to make use of Trace Compass to trace thread states (very very basic threading), specific finite state machines in the code, call stacks (well, instrumented call enter/exit sequence - not full stack - for short sections of executing code to look for optimizations), etc. TC seems like it could be a great boon to us bare metal developers, if I could figure it out. I'm not a Linux or Java developer, so I'm trying to figure out how to bend TC to my will.
I'm successfully putting basic trace info (event timestamp + test events like ThreadRun, ThreadStop, etc.) into CTF and getting Eclipse to import it. I can see the list/table of events and event contents. However the trace views (call graph analysis, critical path, etc.) don't populate like hope. I'm guessing this is because these are tailored for Linux/LTTng and I'm not presenting info in a format it understands. I've also tried to implement custom xml per the "Data driven analysis" http://archive.eclipse.org/tracecompass/doc/stable/org.eclipse.tracecompass.doc.user/Data-driven-analysis.html#Data_driven_analysis in the Trace Compass User's Guide using xml but not having a ton of success. Not knowing what's going on inside Trace Compass it is difficult to know what the elements and attributes do.
Are there any tutorials geared toward me: bare metal embedded guy (non-Linux/Java) who wants to make use of Trace Compass?
Thanks for any help.
Re: Help non-Linux/non-Java embedded C developer make use of Trace Compass [message #1816892 is a reply to message #1794462] |
Mon, 11 November 2019 04:21   |
Buck Fobb wrote on Thu, 30 August 2018 21:27I'm developing C on bare metal ARM Cortex (M3) with a very basic custom OS (no Linux)
I has similar question. I use simple RTOS, and I try add tracing in core (using barectf). I has CTF binary file and metadata file, I can import it in TraceCompass and i can view all event:
Timestamp Channel Event type Contents
07:00:00.000 080 000 channel0_0 isr_enter
07:00:00.000 080 000 channel0_0 thread_ready thread_id=3927689344
07:00:00.000 080 000 channel0_0 thread_ready thread_id=3927689152
07:00:00.000 080 000 channel0_0 thread_ready thread_id=3927688960
07:00:00.000 080 000 channel0_0 isr_exit
07:00:00.000 080 000 channel0_0 thread_switched_out thread_id=3927690624
07:00:00.000 080 000 channel0_0 thread_switched_in thread_id=3927689344
07:00:00.000 080 000 channel0_0 thread_switched_out thread_id=3927689344
07:00:00.000 080 000 channel0_0 thread_switched_in thread_id=3927689152
07:00:00.000 080 000 channel0_0 thread_switched_out thread_id=3927689152
What I should do to see Flow Control grapf (similar to)? What has changed over the year? Is it enough for me to write the correct metadata file? Or I need write additional XML/XSD file? Buck FobbFriend, can you tell us what you did and your success?
Matthew Khouzam, BTF look interested, but it is ASCII text format, and slowly (as compared with CTF). Can I convert my binary CTF files in BTF format?
Re: Help non-Linux/non-Java embedded C developer make use of Trace Compass [message #1817195 is a reply to message #1817184] |
Mon, 18 November 2019 07:32  |
2- Alas, it's in the code base. But I will drop it here:
* Copyright (c) 2015 Ericsson
* All rights reserved. This program and the accompanying materials are
* made available under the terms of the Eclipse Public License v1.0 which
* accompanies this distribution, and is available at
* http://www.eclipse.org/legal/epl-v10.html
* Contributors:
* Alexandre Montplaisir - Initial API and implementation
package org.eclipse.tracecompass.analysis.os.linux.core.trace;
import java.util.Collection;
import org.eclipse.jdt.annotation.NonNull;
import org.eclipse.jdt.annotation.Nullable;
import com.google.common.collect.ImmutableList;
* A kernel event layout to be used by default. This can be useful for
* data-driven traces for example, where they can provide whatever event names
* they want.
* Due to historical reasons, the definitions are the same as LTTng event names.
* @author Alexandre Montplaisir
* @since 1.0
public class DefaultEventLayout implements IKernelAnalysisEventLayout {
private static @Nullable DefaultEventLayout INSTANCE;
* The instance of this event layout
* This object is completely immutable, so no need to create additional
* instances via the constructor.
* @return the instance
* @since 2.0
public static synchronized DefaultEventLayout getInstance() {
DefaultEventLayout inst = INSTANCE;
if (inst == null) {
inst = new DefaultEventLayout();
INSTANCE = inst;
return inst;
/* Event names */
private static final String IRQ_HANDLER_ENTRY = "irq_handler_entry"; //$NON-NLS-1$
private static final String IRQ_HANDLER_EXIT = "irq_handler_exit"; //$NON-NLS-1$
private static final String SOFTIRQ_ENTRY = "softirq_entry"; //$NON-NLS-1$
private static final String SOFTIRQ_EXIT = "softirq_exit"; //$NON-NLS-1$
private static final String SOFTIRQ_RAISE = "softirq_raise"; //$NON-NLS-1$
private static final String HRTIMER_START = "hrtimer_start"; //$NON-NLS-1$
private static final String HRTIMER_CANCEL = "hrtimer_cancel"; //$NON-NLS-1$
private static final String HRTIMER_EXPIRE_ENTRY = "hrtimer_expire_entry"; //$NON-NLS-1$
private static final String HRTIMER_EXPIRE_EXIT = "hrtimer_expire_exit"; //$NON-NLS-1$
private static final String SCHED_SWITCH = "sched_switch"; //$NON-NLS-1$
private static final String SCHED_PI_SETPRIO = "sched_pi_setprio"; //$NON-NLS-1$
private static final String SCHED_TTWU = "sched_ttwu"; //$NON-NLS-1$
private static final String SCHED_WAKING = "sched_waking"; //$NON-NLS-1$
private static final String SCHED_WAKEUP = "sched_wakeup"; //$NON-NLS-1$
private static final String SCHED_WAKEUP_NEW = "sched_wakeup_new"; //$NON-NLS-1$
private static final Collection<String> SCHED_WAKEUP_EVENTS = ImmutableList.of(SCHED_WAKEUP, SCHED_WAKEUP_NEW);
private static final String SCHED_PROCESS_FORK = "sched_process_fork"; //$NON-NLS-1$
private static final String SCHED_PROCESS_EXIT = "sched_process_exit"; //$NON-NLS-1$
private static final String SCHED_PROCESS_FREE = "sched_process_free"; //$NON-NLS-1$
private static final String SCHED_PROCESS_EXEC = "sched_process_exec"; //$NON-NLS-1$
private static final String STATEDUMP_PROCESS_STATE = "lttng_statedump_process_state"; //$NON-NLS-1$
private static final String SYSCALL_ENTRY_PREFIX = "sys_"; //$NON-NLS-1$
private static final String COMPAT_SYSCALL_ENTRY_PREFIX = "compat_sys_"; //$NON-NLS-1$
private static final String SYSCALL_EXIT_PREFIX = "exit_syscall"; //$NON-NLS-1$
/* Field names */
private static final String IRQ = "irq"; //$NON-NLS-1$
private static final String TID = "tid"; //$NON-NLS-1$
private static final String VEC = "vec"; //$NON-NLS-1$
private static final String PREV_TID = "prev_tid"; //$NON-NLS-1$
private static final String PREV_STATE = "prev_state"; //$NON-NLS-1$
private static final String NEXT_COMM = "next_comm"; //$NON-NLS-1$
private static final String NEXT_TID = "next_tid"; //$NON-NLS-1$
private static final String PARENT_TID = "parent_tid"; //$NON-NLS-1$
private static final String CHILD_COMM = "child_comm"; //$NON-NLS-1$
private static final String CHILD_TID = "child_tid"; //$NON-NLS-1$
private static final String CHILD_PID = "child_pid"; //$NON-NLS-1$
private static final String PRIO = "prio"; //$NON-NLS-1$
private static final String NEW_PRIO = "newprio"; //$NON-NLS-1$
private static final String PREV_PRIO = "prev_prio"; //$NON-NLS-1$
private static final String NEXT_PRIO = "next_prio"; //$NON-NLS-1$
private static final String COMM = "comm"; //$NON-NLS-1$
private static final String NAME = "name"; //$NON-NLS-1$
private static final String STATUS = "status"; //$NON-NLS-1$
private static final String PREV_COMM = "prev_comm"; //$NON-NLS-1$
private static final String FILENAME = "filename"; //$NON-NLS-1$
private static final String HRTIMER = "hrtimer"; //$NON-NLS-1$
private static final String FUNCTION = "function"; //$NON-NLS-1$
private static final String EXPIRES = "expires"; //$NON-NLS-1$
private static final String NOW = "now"; //$NON-NLS-1$
private static final String SOFT_EXPIRES = "softexpires"; //$NON-NLS-1$
private static final String KMEM_ALLOC = "kmem_mm_page_alloc"; //$NON-NLS-1$
private static final String KMEM_FREE = "kmem_mm_page_free"; //$NON-NLS-1$
private static final String ORDER = "order"; //$NON-NLS-1$
* Constructor, to be used by classes extending this one. To get an instance
* of this class, INSTANCE should be used.
* @since 2.0
protected DefaultEventLayout() {
// Event names
public String eventIrqHandlerEntry() {
return IRQ_HANDLER_ENTRY;
public String eventIrqHandlerExit() {
return IRQ_HANDLER_EXIT;
public String eventSoftIrqEntry() {
return SOFTIRQ_ENTRY;
public String eventSoftIrqExit() {
return SOFTIRQ_EXIT;
public String eventSoftIrqRaise() {
return SOFTIRQ_RAISE;
public String eventSchedSwitch() {
return SCHED_SWITCH;
* @since 1.0
public String eventSchedPiSetprio() {
return SCHED_PI_SETPRIO;
public Collection<String> eventsSchedWakeup() {
return SCHED_WAKEUP_EVENTS;
public String eventSchedProcessFork() {
return SCHED_PROCESS_FORK;
public String eventSchedProcessExit() {
return SCHED_PROCESS_EXIT;
public String eventSchedProcessFree() {
return SCHED_PROCESS_FREE;
public @NonNull String eventStatedumpProcessState() {
return STATEDUMP_PROCESS_STATE;
public String eventSyscallEntryPrefix() {
return SYSCALL_ENTRY_PREFIX;
public String eventCompatSyscallEntryPrefix() {
return COMPAT_SYSCALL_ENTRY_PREFIX;
public String eventSyscallExitPrefix() {
return SYSCALL_EXIT_PREFIX;
/** @since 2.0 */
public String eventCompatSyscallExitPrefix() {
* @since 2.0
public String eventKmemPageAlloc() {
return KMEM_ALLOC;
* @since 2.0
public String eventKmemPageFree() {
return KMEM_FREE;
// Event field names
public String fieldIrq() {
return IRQ;
public String fieldVec() {
return VEC;
public String fieldTid() {
return TID;
public String fieldPrevTid() {
return PREV_TID;
public String fieldPrevState() {
return PREV_STATE;
public String fieldNextComm() {
return NEXT_COMM;
public String fieldNextTid() {
return NEXT_TID;
public String fieldChildComm() {
return CHILD_COMM;
public String fieldParentTid() {
return PARENT_TID;
public String fieldChildTid() {
return CHILD_TID;
public String fieldChildPid() {
return CHILD_PID;
/** @since 1.0 */
public String fieldPrio() {
return PRIO;
/** @since 1.0 */
public String fieldNewPrio() {
return NEW_PRIO;
* @since 2.0
public String fieldPrevPrio() {
return PREV_PRIO;
/** @since 1.0 */
public String fieldNextPrio() {
return NEXT_PRIO;
/** @since 2.0 */
public String fieldComm() {
return COMM;
/** @since 2.0 */
public String fieldName() {
return NAME;
/** @since 2.0 */
public String fieldStatus() {
return STATUS;
/** @since 2.0 */
public String fieldPrevComm() {
return PREV_COMM;
/** @since 2.0 */
public String fieldFilename() {
return FILENAME;
/** @since 2.0 */
public String eventSchedProcessExec() {
return SCHED_PROCESS_EXEC;
/** @since 2.0 */
public String eventSchedProcessWakeup() {
return SCHED_WAKEUP;
/** @since 2.0 */
public String eventSchedProcessWakeupNew() {
return SCHED_WAKEUP_NEW;
/** @since 2.0 */
public String eventHRTimerStart() {
return HRTIMER_START;
/** @since 2.0 */
public String eventHRTimerCancel() {
return HRTIMER_CANCEL;
/** @since 2.0 */
public String eventHRTimerExpireEntry() {
return HRTIMER_EXPIRE_ENTRY;
/** @since 2.0 */
public String eventHRTimerExpireExit() {
return HRTIMER_EXPIRE_EXIT;
* Event indicating the source of the wakeup signal.
* @return The name of the event
* @since 2.0
public String eventSchedProcessTTWU() {
return SCHED_TTWU;
/** @since 2.0 */
public String fieldHRtimer() {
return HRTIMER;
/** @since 2.0 */
public String fieldHRtimerFunction() {
return FUNCTION;
/** @since 2.0 */
public String fieldHRtimerExpires() {
return EXPIRES;
/** @since 2.0 */
public String fieldHRtimerSoftexpires() {
return SOFT_EXPIRES;
/** @since 2.0 */
public String fieldHRtimerNow() {
return NOW;
public String eventSchedProcessWaking() {
return SCHED_WAKING;
* @since 2.2
public @NonNull String fieldOrder() {
return ORDER;
FUDForum. Page generated in 0.04469 seconds
