Home » Modeling » TMF (Xtext) » mismatched input '0' expecting RULE_ID
mismatched input '0' expecting RULE_ID [message #1816055] Fri, 18 October 2019 05:10 Go to next message
Hello everyone, I am not sure if this question is related with the use of keywords so I will ask it again. Apologies if this is the case. For the following grammar:
Import:
	'import' importURI=STRING;
TaskDef:
	'TaskDef' name=ID 'on' 'Task=' mapped=[Task|QualifiedNamed] '{'
		(statements+=Statement)*
QualifiedNamed:
	ID ('.' ID)*
And the following concrete grammar:
TaskDef FrontSensor on Task=0 {
  out = 2
I am getting the following message:
The class Task is imported. Any clue about what is going on?
Regards, Matias.
Re: mismatched input '0' expecting RULE_ID [message #1816056 is a reply to message #1816055] Fri, 18 October 2019 05:13 Go to previous messageGo to next message
0 is an INT (or a keyword depending on your grammar)
https://blogs.itemis.com/en/xtext-hint-identifiers-conflicting-with-keywords
QualifiedNamed allows ID only
=> you can use a MyID
MyID: ID | INT;
or
MyID: ID | '0';
depending on your situation
and use
MyID in QualifiedName
Re: mismatched input '0' expecting RULE_ID [message #1816065 is a reply to message #1816056] Fri, 18 October 2019 08:28 Go to previous messageGo to next message
Hello Christian and thanks for the quick answer. I tried:
TaskDef:
QualifiedNamed:
	MyID ('.' MyID)*
MyID: ID | INT;
I am getting this:
no viable alternative at input '2'
It works well when I use:
MyID: ID | '0';
However, I have to do it for every value?, e.g.,:
MyID: ID | '0' | '1';
In my model, the ID I am using is an EString named TaskId.
Regards, Matias.
[Updated on: Mon, 21 October 2019 04:09] by Moderator
Re: mismatched input '0' expecting RULE_ID [message #1816067 is a reply to message #1816065] Fri, 18 October 2019 08:45 Go to previous messageGo to next message
I fixed by using:
QualifiedNamed:
	MyID ('.' MyID)*
MyID: ID | NUMBER;
terminal NUMBER returns ecore::EBigDecimal:
	('0'..'9')* ('.' ('0'..'9')+)?;
I am not sure if this is correct.
Re: mismatched input '0' expecting RULE_ID [message #1816068 is a reply to message #1816067] Fri, 18 October 2019 09:33 Go to previous messageGo to next message
I have. No clue. what is in your grammar besides your snippet
[Updated on: Fri, 18 October 2019 09:34] by Moderator
Re: mismatched input '0' expecting RULE_ID [message #1816099 is a reply to message #1816068] Mon, 21 October 2019 04:09 Go to previous messageGo to next message
Apologies for that. Here is the whole grammar:
grammar xtext.tasks.MyTasks with org.eclipse.xtext.common.Terminals
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
import "platform:/resource/my.metamodel.org/model/mymodel.ecore" as mymodel
generate myTasks "http://www.metamodel.org/xtext/tasks/MyTasks"
Module:
	'module' name=ID '{'
	(imports+=Import)*
	(taskdefs+=TaskDef)*
Import:
TaskDef:
	'TaskDef' name=ID 'on' 'Task=' mapped=[mymodel::Task|QualifiedNamed] '{'
QualifiedNamed:
	MyID ('.' MyID)*
MyID: ID | NUMBER;
Re: mismatched input '0' expecting RULE_ID [message #1816103 is a reply to message #1816099] Mon, 21 October 2019 05:49 Go to previous message
Yes the fix looks legit
Previous Topic:Add Xtext content to toolbar
Next Topic:Working directory for xtext plugin
Current Time: Sun Jul 20 12:03:21 EDT 2025
Powered by FUDForum. Page generated in 0.06595 seconds
